Panel door stile expansion
Posted by taylorsway (My Page) on
Tue, Dec 9, 08 at 16:03
An age old problem I know... but despite my best efforts
to glue the offending stile to keep it from expanding each
summer, I am now faced with the same problem , same interior door, again. Before I take the clamps to the door to tighten it up (now that drier air exists in the house), so the door will close efficiently, does anybody have any long term solution to this problem apart from replacing
the door. (Fyi, we're dealing with a four panel clear
pine, stained, urethane coated interior door.
Thanks..
RE: Panel door stile expansion
The usual solution is to seal the top and bottom of the door so moisture can't get in.
I've been in 80 year old houses that have never had these sealed.
Ron
It's probably not the stiles expanding but the panels in the door. They are too big or glued to the stiles. The panel need to be able to float in the door so that they can expand and shrink.
If the stiles and rails can be pulled apart then do it and adjust the panels so they float in the door.
