Tue, Dec 30, 08 at 11:48
| I have a sliding glass door that has the weather strip gasket missing. It allows the heat to escape. Where do I get this gasket replaced and is it hard to put on? Right now the door is duct taped shut which is really annoying since I can't use the door. |
| You will have the best luck by contacting the manufacturer of your door. They will have the proper seal to fir your door. |
- Posted by macattac (windowpartsguy@gmail.com) on Tue, Dec 30, 08 at 22:06
| Are you referring to the "interlock" (where the sliding unit and fixed unit overlap) or the Jamb Seal (where the sliding unit closes into the shut position)? The last interlock i did for someone, the part was around $60.00. That was an Andersen. |
