Wed, Dec 31, 08 at 11:12
| I have a Craftsman opener 139.53975SRT1. Recently the garage door started opening at all different times. I suspected that someone nearby had a smilar opener and the rolling code just happened to match. I cleared all codes and reprogrammed the remotes and the keypad. The control console and the keypad will open AND close the door, but the 2 remotes will only OPEN. They will not close the door. The opener does not flash or even attempt to close from the remotes. |
- Posted by don_1_2006 (My Page) on Wed, Dec 31, 08 at 12:49
| Very strange. The only thing I can think of is maybe the lock button has been pressed on your wall control. If the small light is flashing and you have the wall control with 3 buttons hold the lock button in for 3 seconds. The flashing should stop and your remotes should work. I can think of no reason why the remotes would open your door but not close it. I think you ought to try this once again. |
- Posted by don_1_2006 (My Page) on Wed, Dec 31, 08 at 12:53
| One other thing I forgot to mention is your wall control could be bad. This could be the cause of your original problem which you thought were your neighbors. Also check the wiring from the wall control to the motor unit for staples cutting into the insulation. |
