vinyl siding
Posted by tkhooper (My Page) on
Sun, Dec 12, 10 at 9:45
I just had someone repair all the holes in my siding. So I was cleaning out my gutters and found 2 more holes. Does this ever end?
RE: vinyl siding
What do you figure is causing these "holes" in your siding?
RE: vinyl siding
I have no idea.
RE: vinyl siding
What do the holes look like and how were they repaired? I would think repair involves replacing the whole damaged piece of siding.
Pictures would certainly help. From pictures of the damage it might be possible to identify the cause; impact, rodents, etc. Eliminate the cause and you'll eliminate any more holes.
RE: vinyl siding
The repairs were done by cutting out the damaged section and replacing it with a larger cut piece of siding.
One is circular and one is a crack running along the panel for a couple of inches. Very different from one another.
