| I'm having no luck finding an odor source in the house,
a smell of rotten eggs (or sulfur?) coming out of my heat vents in the winter. this all started 2 years ago, I had a new heating system put in, a Trane, Electric Furnace and heat pump and A/C. A few months before, I also had a new hot water heater put in a Rheem Powervent, propane hot water heater. These are the only major changes made before the start of the smell. I attribute the issue to one or the other. on to the smell, the smell usually occurs very early in the morning, after my shower (hot water heater has been running), smells for about a few minutes and dissipates very quickly, about a minute. I've smelled the odor at other times, during the night, and during the afternoon, I've smelled the odor coming out of the sink (on septic, last pumped about 2 1/2 years ago), I've noticed the smell in my water, which leads me to believe I'm crazy, but family members have verified, I haven't noticed the odor in the summer when the furnace/ heat pump is not used nor have I noticed the smell in the air return vents. I have not found any dead animals (i.e. mice) in the ducting anywhere water comes into the tank from the well, goes into a softener (doesn't smell like odor) , then to a hot water
There is no history in this area that I am aware of that documents sulfur in the water. my research shows this as a possibility. sulfur accumulates in hot water heater as it sits idle overnight, released when the water heats. We've taken to bottled water for drinking, have had no ill effects from drinking tap (I make coffee with it every day)
I also might add,
any ideas on how to track down the source of the smell. tia |
- Posted by mightyanvil (My Page) on Fri, Dec 26, 08 at 10:44
| It is possible that there are sulfate reducing bacteria (SRB) in your supply water that create hydrogen sulfide gas probably on the hot water side, possibly from the water heater (try only using just the hot water in the morning, then the cold water). If it is only in the hot water, it might be building up overnight in the tank and discharging when you turn on the water in the morning. If you have a humidifier on your furnace it could be getting into the warm air supply as well. Check out any place where water sits overnight. Also, a magnesium corrosion control rod in your water heater might be chemically reducing naturally occurring sulfates into hydrogen sulfide. If it is in the water, any plumber should know how to deal with it. Good luck with it. |
Here is a link that might be useful: sulfates and hydrogen sulfide
- Posted by kathyg_in_mi (My Page) on Fri, Dec 26, 08 at 10:53
| We had that with our hot water heater. DH removed the rod and no more smell! There is a special replacement rod you can buy, but we thought too many $$, so never replaced it. No problems with it at all. Hated that smell. Kathy G in MI we have hard water with a water softener |
