Thu, Dec 17, 09 at 7:28
| The electricians in installing some new wiring, made some holes 6"x6" holes in old plaster ceilings. What would be the best and easiest way of repairing them. I have 2 options: use drywall to cover them and screw it into the ceiling or would using a mesh and skim coat with ? joint compound work? Are there any other options? What else would you suggest? Thanks |
| Fill the hole with drywall. Tape and mud it. |
- Posted by chipster_2007 (My Page) on Thu, Dec 17, 09 at 11:07
| Thank you...is "mud" joint compound or some other material/product? Brand name you would recommend. Thanks |
| What kind of plaster? Two coat plaster uses gypsum lath and the piece they cut out makes a perfect patch. Three coat plaster on wood lath is a little harder to repair, but a pieces of drywall makes a good base. Veneer plaster (one coat on blue board) is also easy to fix. |
