Found construction 'holes' in carwlspace wall
Posted by braytonak (My Page) on
Sun, Nov 9, 08 at 18:58
I was insulating some pipes in my crawlspace (hot potable water lines and a big, long vent for the Jenn Air). In the process I had started to notice areas between the floor joists where they meet the outside wall, just on top of the foundation, where cold air could be felt and daylight was clearly visible after removing the fiberglass sqaures.
I don't know how common this is, but I found an area under my front door where the exterior wall hadn't been built down all the way to cover the ends of the joists. To 'close' the space between the joists, the builders had taken chunks of 2x6's and placed them in the spaces. This, of course, leaves huge gaps because floor joists are skinny in their center portion. To make it worse, the joists had been sistered for some reason. So a 2x6 sistered to a joist leaves a nice channel in the middle.
I managed to seal all these gaps with spray foam and then replaced the little squares of fiberglass that had been concealing it for the past 25 years. There's only one spot where the spray foam nozzle simply couldn't reach due to distance and a narrow gap for accessibility.
The pay off was nearly immediate! This morning I checked my entryway floor and it was clearly much warmer than it had ever been. I've always thought I'd paid enough attention to things like this, but I guess it pays to dig deeper. I'll have to climb under my front porch in the spring to seal up any more concealed holes, unless anyone out there wasn't to volunteer to dive under the snow and do it now? :-)
RE: Found construction 'holes' in carwlspace wall
"There's only one spot where the spray foam nozzle simply couldn't reach due to distance and a narrow gap for accessibility."
I extend mine by using straws. If they are not a tight fit into each other just overlap and tape them. Doesn't have to be pretty, you'll throw them away when the can is empty.
unless it was intentional as a means to ventilate the crawlspace.
hendricus: I thought of that, but I don't have any straws. But even with that, the space available to work with is minimal. I can just fit my hand in the area, yet it's about a forearm length away. It will be easier to climb under the porch. (I say that now...wait till I see the bugs.)
davidandkasie: There's plenty of other proper vents provided for that purpose. This is obviously some kind of construction flub or shortcut. Our house was built back when the inspectors were known for doing curbside inspections. Fortunately this doesn't seem to have caused any structural issues that I can detect.
I'm actually making slow progress towards getting the crawlspace to be sealed. We monitor the humidity down there with a digital remote sensor and the winter is the best time to start some of this work due to the dryer weather.
