| I'm involved in a water damage repair involving replacement of soggy drywall and insulation (little mold). These same outer walls, one above the other have turned out to have extra thin cavities (3/4 furring over block on the upper two floors, and 2x4 studs turned on their side on the lowest floor, which is partially below grade. We replaced about 4 to 8 linear feet of water-logged lumber on each floor. Building thicker walls is not in the cards, so what can be done about the insulation? I am considering 1 1/2" xps in the basement floor cavities, cut to fit, with all gaps foamed. On the upper floors, I only have 3/4" depth, which means same thing, but with 3/4" xps. Then I'm going to foam all the gaps. No other vapor barrier, then close it up. Thoughts on this plan of attack? Thanks much. |
| Use double-bubble foil-wrapped insulation. http://www.radiantbarrier.com/double-bubble-insulation.htm Works great, easy to install, and best of all, if installed in layers with an air gap between each piece, the R value is multiplied. Call them, they can give you the R values. I install this everywhere - no mask or eye protection necessary like with pink. |
- Posted by energy_rater_la (My Page) on Tue, Nov 27, 12 at 11:32
| 3/4" two layers for upper floor with staggered seams then install sheetrock screwed to 1x's. use highest R-value foam sheathing. plan for basement..stays as you described. foil bubble foil is a waste of money & effort to what was the source of moisture intrustion that best of luck. |
| "foil bubble foil is a waste of money & effort to installed. little to no R-value it is about emissivity. even as a radiant barrier correctly installed in an attic in a hot climate..there are cheaper products that do the exact same thing for 1/4 of the cost. foil bubble foil is all hype and little real world savings." What FACTS are you using to base your statement?? There is very little effort needed to install it - you unroll it and cut to size with a razor - the same effort needed for a foam product, and, it is bendable,not breakable like foam and leaves no waste (foam pieces). Cost?? What material do you prefer and what is the cost? Double-bubble, pre-cut 500 sq ft. cut to 24" (for rafter installs) is $162 delivered to me. What is the cost of your product??? What is the R value of your product? Double-bubble stacked x3 with 1/2" air gap = r50. This is FACT. What is the fire rating of your product? What is the resulting carcinogens in fire tests of your product? Homebound - I don't work for innovative insulation, I just use their products effectively over a long period of time. If you want facts and not baseless conjecture, call them, ask for a salesman or Dan (the owner) they are more than willing to back their products. |
| Thanks for the comments. The source of water was a damaged scupper on a flat roof. They just had it repaired and reroofed. I'm in the midst of cutting and installing xps. energy_rater_la, tjdabomb, Thanks much. |
- Posted by energy_rater_la (My Page) on Tue, Nov 27, 12 at 19:12
| no. put the 1st layer xps between furring strips already there. then put another 2nd layer that will cover both the layer of xps against the block & furring strips. when installing drywall use longer screws and not suprised you didn't find R-value. tj..for my radiant barrier in the attic..where I'm very pleased with radiant barrier in attic even with 4'x8' sheets of iso board ( R-7 foam Double-bubble stacked x3 with 1/2" air gap = r50. This is FACT. I'm not the only person to know this is true. http://www.energyvanguard.com/blog-building-science-HERS-BPI/bid/29497 /The-Foil-Faced-Bubble-Wrap-Sham-Understanding-Radiant-Barriers read the comments Kvalue folks strike again! LOL! |
| http://www.nasa.gov/centers/johnson/home/get_green.html One hand, NASA engineer, other hand, who??? "older people with RB rolled over insulation in attics. The only scam is the installer - if you don't install it correctly, it doesn't work correctly. Kinda like changing your oil and putting the oil filter in the glove compartment! LOL! |
- Posted by energy_rater_la (My Page) on Tue, Nov 27, 12 at 21:43
| from the nasa article " The biggest change, Flahaut said, came from the new air conditioner" Radiant barriers in attics are great. but it is the whole house approach that saves money & energy. with the oversell of low emissivity products you cutting off his nose to spite his face. this the article that preceeds the one linked you have to admit..some of the claims |
| I'm trying to comprehend why would one need a radiant barrier for a basement wall application without a radiant heat source (or much of one) to reflect down there? This is aside from any secondary benefits that it might provide, i.e. moisture barrier, etc. On the other hand, this might inspire me to add some aluminum foil behind our radiators upstairs. |
- Posted by energy_rater_la (My Page) on Wed, Nov 28, 12 at 8:38
| misuse of the product. not understanding application. hype. |
- Posted by alan_s_thefirst (My Page) on Wed, Nov 28, 12 at 16:10
| I like Isoboard, especially the stuff with the foil on it - it can act as its own vapour barrier. You could also use a layer or two of isoboard without the foil, since you shouldn't double up vapour/air barrier, then a layer of the mylar foil bubble stuff, which (I don't know if it's certified as such) could be your air/vapour barrier. Of course, you couldn't use it under drywall - too springy - so you'd have to use it between the furring strips, with regular vapour over the furring strips, and taped. |
| from the nasa article " The biggest change, Flahaut said, came from the new air conditioner" Radiant barriers in attics are great. but it is the whole house approach that saves money & energy. " "Miller spent about $250 on supplies for his radiant barrier � four rolls of barrier and one staple gun � and installed it himself over two days in December of 2005. The following summer, his electricity bill showed that he used about 6 percent fewer kilowatt hours than he had in previous summers, with a correction for the difference in average temperatures included in the calculation. Based on that, he determined that he saved $119 in that first summer, alone. By the next summer it was paid off, and last summer the difference was pure savings. " Two NASA engineers, two separate installations with both installations requiring different means to an end. I bet those astronauts were sure happy with their foil suits when they were in temperatures that ranged from 250 �F above to 400 �F below zero Fahrenheit. This feat in temperature control technology enabled the astronauts to work inside the Apollo Command Module wearing short-sleeve shirts. Gotta love those short-sleeve shirts!! |
| You want to use EXPS not XPS. Either Styrofoam by Dow Chemical or Foamular by Owens Corning. They have an R value of 5 per inch of thickness and they are anti hydrogenous. You could use "Stuff" the isocyanurate in a can to seal openings. You should put a 6 mil Poly vapor barrier on the warm side, which is probably on the inside. staple this temporarily and then screw your drywall to the studs, furring strips. This is OK but it is still not much insulation if you are in a cold area. Good Luck. Two layers of 3/4 inch with staggered joints is always better than one layer of 1.5, but if you are just cutting between 2 x lumber on the flat it wont make much difference. You could install a second one inch layer over the nailers and the infill insulation and screw through it to the nailers, as it has good compressive strength. About 40PSI |
- Posted by energy_rater_la (My Page) on Thu, Nov 29, 12 at 20:30
| would you need to poly vapor barrier? seems to me that the foamboard would work as long as seams are staggered & taped. my climate is hot humid, so interior vapor just curious. |
| Sorry to revive this post, but this scientific review seems to do a fine job of explaining the science behind radiant barrier usage. My takeaway is that it might only be worth it in attics in warm climates and properly installed, but that's about it. Certainly not in wall cavities where you would need to sacrifice some cavity space to create the necessary air gap in front of the foil face. |
Here is a link that might be useful: Alaska paper
