Can't seal air coming through door gaps
Posted by jaxo (My Page) on
Sun, Nov 20, 11 at 16:41
Air was leaking around the door, so I had the seal replaced. It didn't solve the issues.
I now see that it is because of door security hardware that the door does not shut 100% flush with the door jamb. Because of this, air gets between the deadbolt locks and the jamb and also by the bottom of the door near the floor and the door jamb.
I don't want to remove the hardware, so is there some kind of additional flexible seal that can be installed either on the door or in the door jamb that will make the door air tight won't stop the door from closing?
I want to stop cold air from coming in and also stop insects from climbing through the gap near the floor.
RE: Can't seal air coming through door gaps
You need better gaskets.
Things like hollow Teflon tubes are placed on the jamb at the stop bead and can seal just about any size gap.
Try resource Conservation, Baltimore, MD for a good assortment of weatherstripping.
I think its a little easier than adding weather stripping.Unless the jambs are metal,that dead bolt is doing nothing, there is no strike plate. As matter of fact if a thief wants in, it's a stiff shoulder. That stiffener around the door, where the dead bolt is located is doing nothing , unless the door has been hacked.It is the root of your problem, loose it.
From what I can see , you have an adjustable strike plate. That is the plate mounted on the door jamb for the door knob.When you push on the door when closed does it go forward, if so.Loosen the screws on the strike plate and push outwards and re-tighten screws. This should tighten up that gap,a bit.
Actually the door frame is reinforced with metal. A stiff shoulder won't do anything. There is security glass in the door and a vibration sensor on the door that will go off on the first attempt to kick it in.
The other photo wasn't clear, so here is another.
Looks to me like the door wasn't installed square and tru, OR the house has settled enough since installation that a once-square door is no longer.
Plus 1 on the problem being installation!!
I agree that the added metal plate is preventing the w-strip to seal to the door, because the plate has a definite thickness and is causing the w-strip to deflect from the door above and below it.
You need a more conformable w-strip, a thinner plate, or a tapered shim added above and below the plate to transition smoothly without a step. I'm thinking HDPE milled down to a taper and attached with double-sided adhesive.
Casey
What about a very soft and flexible weatherstripping on the door or door jamb that will mold itself to fit and fill in the irregular gap when the door closes?
Any recommendations?
The softer the material, the more prone to wear & tear. The doorknob zone is always hard on these vinyl-wrapped foam w-strips anyway.
I wonder: it's a steel door? So how about a magnetic w-strip that gets a very fine cut through the magnetic part corresponding to the top and bottom of the plate; with the two cuts, the strip can easily step over it without any flexing, keeping tight against both planes. The cuts could be filled with sealant to lock them back together as one unit with the step built in.
Casey
"What about a very soft and flexible weatherstripping on the door or door jamb"
Teflon tubing in the corner of the door jamb and stop.
I gets compressed but does not have a lot of wiping wear to damage it.
the corner of the door just compresses the thin wall flexible tube.
It is held in place with silicone caulk.
I wonder if just getting a storm door outside this door would be the easiest solution, but I don't think I want the hassle of opening 2 doors and a sorm door may interfere with getting the washer dryer outside if they need to be replaced or if I move.
The shim idea might work, but paying someone to do metalwork might not be worth it.
I dont fully understand the Teflon tubing idea.
Ditto on the install. I got a funny feeling who ever installed
the dead bolt used the wrong back set and cut a whole for the dead bolt and used the stiffener to cover the remnants of the original hole.
"I dont fully understand the Teflon tubing idea. "
It is sold as weatherstripping for retrofit on older installations.
The cataglog from resource conservation has this and many other types of weatherstripping.
