| I have an attic that has new blow-in insulation in it. The attic also has a party wall (it's a row house) that is beginning to crumble, with a section of bricks now missing. It's a very old house, so the bricks are soft and lime-based mortar was used.
My questions are:
thanks! |
- Posted by energy_rater_la (My Page) on Sat, Nov 12, 11 at 10:14
| its pretty much a given that your insulation will be compressed and moved about. the time to have done this.. if indeed it can be done..was prior to insulation install. maybe from the other side of party wall?? if the missing row of brick is above your insulation best of luck. |
| Just make sure whomever does the repair uses the correct mortar. Lime mortar is not generally available and must be mixed from scratch. If you use type S (the common grade in the big box stores) it is likely to cause further damage to the old soft bricks. |
