Mon, Nov 9, 09 at 13:28
| It looks like the inner trolley on my garage door opener has actually broken into two peices. the two peices are like two feet apart and I am wondering how I go about replacing this, if it worth replacing or easier to just install a new unit. |
- Posted by don_1_2006 (My Page) on Mon, Nov 9, 09 at 15:28
| The inner trolley is very easy to replace. Disconnect it from the door and slide it back towards the motor unit. Then you can find where the t-rail splits into 2 sections and remove the forward bolt and nut and then loosen the other bolt and nut. This will allow the t-rail to split and hang down. You can now slide the inner trolley off the rail and slide the new part on. Reverse the procedure. |
