how to remove/replace Kohler toilet seat bolts w/ anchor
Posted by homebound (My Page) on
Sun, Nov 18, 12 at 11:34
I'm having trouble removing a seat screws on a Kohler one-piece toilet. Anybody know how to hold the anchor so it doesn't spin while unscrewing the thing? From my online reading, Kohler sells an outageously expensive kit to remove these, which apparently only sometimes works. So....if I drill and/or cut the screw head off, will there be room for a new anchor if some of the old parts are now stuck in the recess? Anybody familiar with this poorly-engineered piece of Kohler junk? They really tick me off with some of their stuff. Thanks much.
RE: how to remove/replace Kohler toilet seat bolts w/ anchor
Oo oh. Someone else reports the same problem:
" KOHLER K-3386-0 Rialto One-Piece Round-Front Toilet, White (Tools & Home Improvement)
This is the worst toilet imaginable. First, the reviewers above are right: this thing plugs up all the time and has to be plunged. Not good, but I can live with that. The real kicker is when (not if) the toilet seat needs to be replaced. This is usually a 5-10 minute job on most toilets. On this thing, it's a two-day project and will cost just under $100. You read that right! The nuts (threaded inserts, actually) are completely enclosed and inaccessible. The only way to get them out is to get a special hacksaw that can fit under the screw heads and saw them off (you DO have one of those special hacksaw's, right? Nope? There's another $15.) Then you have to order special proprietary inserts from Kohler (they don't come with the toilet seat). It's part #84999. Two crummy little bolt inserts with some other junk you don't need. Price? FORTY-SEVEN DOLLARS!!! Yep, you cannot put that new toilet seat on without the $47 (plus S&H) kit from Kohler (plus the cost of the seat) -- oh, and wait a few days for delivery. Some folks have yelled enough at the service rep and got Kohler to send them a kit for free. Good luck with that. For me, I will never buy Kohler again. Any company that continues to sell such unbelievable junk doesn't deserve your money. If you still want this toilet, just remember: you've been warned!'
-from Amazon.com under Kohler toilet seat
What did you end up doing homebound? Hope you found a solution to this Kohler vexation.
It's not yet resolved due to the holiday. I am likely going to jam a scraper tool in there to try to hold the anchor in place while I unscrew the bolt. If that doesn't work, I'll proceed to cutting off (or drill) the screw head with a metal blade. Then I'll figure out the anchor part afterward.
The same house has another problem toilet: a one-piece American Standard champion, but apparently an older model with an older flush valve. New flush valve parts are going to run me around $125 with shipping, which includes an adaptor to upgrade to the newer style flush valve. Insane.
Yea, that's a pity. I just changed out an AS toilet seat and can't believe what you have to do with that Kohler seat. Thanks for the heads up about the AS Champion. I know I'm going to be replacing a toilet soon if the eroded interior enamel bowl finish poses a general water leak problem and I'll be sure to read up on fix it problems ahead of time.
Hope you had a good break from work and enjoyed yourself.
