| Hello,
I am new to this forum. I have a 1950s house with plaster walls and ceilings. We had a leak from a bathroom into our faimly room and it was repaired by someone our painter recommended - we had just moved in at the time and didn't know anyone. Now it is cracking again and I am not sure whom to call. I don't want to call the same painter as I am not happy with his work on other jobs. I wonder if there is something structurally wrong (there is cracking on the second floor too). What kind of person should I call? A contractor? Handyman? Not sure. Thank you. |
| Cracked & sagging plaster is usually caused by water damage, either from leaking plumbing, or a leaking roof. If you have structural problems, like a settling foundation, you might see long diagonal cracks in the walls. If the damaged plaster is a smaller area, maybe 3 by 4 feet or so, then you might find a handyman who can repair the plaster, but if the damage is more extensive, it might be better to rip out all the plaster on the entire ceiling, and put up sheetrock. |
| "...if the damage is more extensive, it might be better to rip out all the plaster on the entire ceiling, and put up sheetrock." Better or easier? |
| I was in panic mode when I saw some plaster cracks in my previous house (which I noticed just prior to selling), figuring that it was a major calamity. Then I bought this house (1950's) and there are cracks everywhere :) Some I patched myself when I painted, others I just left for now. I asked a lot of questions and did a lot of reading. Brickeyee's post capsulates it nicely. The best thing I read was something like: "(when dealing with plaster) expect to patch cracks every time you paint". Also, it is not uncommon for patched-up cracks to just crack again at a later time. In other words, unless you have some major sagging or very deep cracks (or chunks falling off), no big deal. One article even mentioned that it adds a certain old-house charm :) In my case, a lot of cracking happened when new windows were installed, and I have a few in ceiling and door corners. Things would have to get a lot worse before I'd go through the trouble and expense of replacing the plaster with sheetrock. The important things in your case, I'd think, is to make sure everything dried out quickly and completely after that leak. |
| In order to repair the cracks permanently, you are going to have to ensure that the plaster is solidly attached to the lath behind it (if not, the crack just comes back). My advice is to do it yourself with a plaster adhesive--the job isn't too hard. You can always hire a handyman, but repairing plaster is easy to do yourself with the right tools. You drill down to the lath with a masonry bit every 3 inches all along the crack, spray the holes with a conditioner, and then fill with your adhesive. After that, you temporarily clamp the plaster to the lath with screws and washers. Wait 24 hours, remove the screws and you are done! Your plaster is structurally reattached to the lath. You can see how it works with the link below, or check out this old house: |
Here is a link that might be useful: Plaster Repair
| "In order to repair the cracks permanently, you are going to have to ensure that the plaster is solidly attached to the lath behind it (if not, the crack just comes back)." Most plaster cracks are NOT caused by separation from the lath, but by movement of the structure over the years from settling. Unlike drywall, plaster has zero 'give.' Some cracks are 'seasonal,' caused by the expansion and contraction of a wooden structure. The first thing to check is if you do have separation from the lath. While there are methods of attaching the plaster back to the lath, it also needs to be pulled back into plane. If there is no movement you should try and repair the crack. I use Durabond and mesh tape. Make sure you can dio a smooth job, since Durabond is as hard as old plaster and cannot be sanded very much, if at all. Most of the old plaster was actual lime-plaster.
