Sensors on Craftsman GDO
Posted by sklranch (My Page) on
Sat, Oct 25, 08 at 19:29
Sensors on Craftsman GDO. They both are...one is green and the other is Amber...the door will not close completely unless you put just a min of downward pressure with your finger, otherwise it's stops about 12-18 inches from the bottom and goes back up...I thought maybe they were aligned properly, but, the amber one will not change colors regardless of how much I move it....just wondering of the amber light on the one side indicates that sensor is bad?
Thanks for your help.
RE: Sensors on Craftsman GDO
It sounds like you need to adjust the lower limit screw on the unit, or possibly the downward pressure screw. Get a manual and read the part that concerns the adjustment section.
Ron
