| Hello, would love an opinion on this.... We have a 1949 bungalow in SE Michigan and recently discovered the back wall under the kitchen sink was crumbling, and some evidence of minor water leaking in the basement just below it. I had my dad look at it, and it seems like the sprayer pull-out faucet that came with the house when we bought it in 2004 has been leaking and dripping onto the cold connection pipe that runs into the wall, traveling along that pipe and into the hole where it inserts in the wall, probably for a long time. Right now it's hard to tell if there is any other source, but we got an opinion from a former window installer that it doesn't look like it's coming from the kitchen window above the sink.
Had a plumber out to change the faucet, he didn't see any obvious problems with the pipes and fittings (at some point they were changed out to copper pipes), but he didn't go digging into the wall. I did some more poking around that crumbly area after he left, and it's really breaking away, I'm down to wet insulation and some black wood next to the copper pipe, I didn't realize it was wet back there, I thought the damage was just to the surface plaster. I can poke a pen several inches into the wall past the pipe, and it seems like there's some wet, sandy stuff in there, too (mortar?). The wall about an inch or two above where those pipes go into it seems pretty solid. Just trying to figure out if this is just residual dampness from the bad faucet and a fix we can do ourselves. If we open it up a bit more, get out what wet stuff we can reach and let it dry out, maybe hit it with some bleach, I assume we'd then need to re-insulate and patch up the hole so the pipes don't freeze? Do I need to worry about any rotted wood if it's not supporting something? Is there anything else I should be looking for as a potential alternate leak source other than the faucet? We're way underwater with a yucky old kitchen, so we don't need to get fancy, but I want to fix it well enough so that we don't have more expensive issues later should we decide to stay for the long haul. Thanks in advance for any suggestions. |
| If you're sure the wood is not structural, then it shouldn't have to be replaced. Removing wet insulation, crumbly walboard, etc and cutting away rotted wood will let the area dry and allow you to see if the problem is more extensive. Let it dry before reinsulating. If it doesn't dry, there might be another problem. |
| thank you! |
- Posted by alan_s_thefirst (My Page) on Fri, Oct 26, 12 at 17:25
| If the wood is black, you've got mould. At the very least, treat it with an anti-mould spray or bleach. Give it a couple of weeks so you're sure it's dry, but make sure the pipes don't freeze if you've removed the insulation already. |
| Thanks Alan, the black mold on the wood totally came off with 50/50 bleach and water, so the wood wasn't actually rotted, it was just on the surface, and I pulled out everything wet and put a fan on it for more than 48 hours straight, so everything seems really dry now. My next door neighbor's dad is a semi retired contractor, he came over and tightened the part where the horizontal copper pipe attaches to the vertical one, and it stopped it's very slow drip, I had been catching it with a paper towel wrapped around the pipe while the fan was on it. So I think we've fixed the water issue, got some pipe insulation to help with condensation, and batting insulation for the wall cavity, he's got some extra drywall, so we'll be ready to patch by next week I think. I learned some stuff about home maintenance with this one! Usually in the past I always just found repair work to be an annoying PIA, but now I'm actually curious how it works and how to fix it. ;-) Well, the minor stuff, anyway. |
