Spot Repair / Patch Aluminum Siding with Vinyl?
Posted by snikcilla (My Page) on
Sat, Oct 10, 09 at 14:36
Hi,
I'm having trouble finding a small bit of aluminum siding for a repair job (without having to special order).
Wondering if I can use Vinyl siding (which I can buy readily at Home Depot) to patch a small area next to existing aluminum siding?
Are the sizes the same? Would they inter-lock with each other? etc.
I know it may not look that great (which I'm not worried about), just need to know if it would logistically work?!
Thanks for any input--
RE: Spot Repair / Patch Aluminum Siding with Vinyl?
I would strongly assume that they won't interlock together.
They ARE different products, different manufacturer, and different materials.
Generically - the 'size' (for whatever your current reveal is) would be the same. Since siding is generally installed with several different standard 'reveal' options. ie: 5,6,8,10" reveals...
You mention HD. HD sells aluminum tape in their ducting, heating area... This is very thin stuff... but it is aluminum. For example - I have a role of 2.5" wide 'Nashua 324A' aluminum tape. Nashua is manufactured by Covcorp, in KY.
Can't you buy a small piece or short section of your current aluminum siding, and then just fold or glue, or tape that in?? Since your planning on jury rigging some vinyl - I'm just wondering why you don't do the same with aluminum instead.
Or possibly "I know it may not look that great (which I'm not worried about)" buy a piece of Cedar siding, or just use a piece of cedar board - which is extremely insect repellant - cut it to fit; wrap it up with some tar paper; cover that with the aluminum tape; nail it up; and than paint to match.
Thinking - since aluminum siding is going to be THIN - it might be better to purchase a board of James Hardi Cement Siding. This is thin - will not rot; costs only $6; wouldn't need to have tar paper; can be nailed up; and have the aluminum tape applied over it.
Here is a link that might be useful: Nashua Tape manufacturer
