Picket Fence Repair
Posted by kelko (My Page) on
Tue, Oct 2, 12 at 14:22
I am replacing my picket fence and have already done about six 8-foot sections. I have several to go. I have used one screw on top and bottom of the 3-inch wide pickets and I really don't like the way the holes show. I tried painting them, but they're still noticeable. My questions are (1) should I be using nails instead of screws, (2) if I keep using the screws, do you think the pickets will eventually cup with only one nail on top and bottom (they're primed and painted white); (3) if I switch to nails and rent a nail gun, what type of nail should I use that won't rust or react to the cedar wood, and (4) should I use 4 nails total (two on top and bottom)? Thanks for any advice you can give me.
RE: Picket Fence Repair
You could try caps for the screws.
Here is a link that might be useful: screw caps
Yes they will cup with only one nail or screw in each picket. Stainless Steel should be used regardless if screws or nails. Go to a lumberyard and get "trim head" screws in stainless or if you choose to rent a nailer use a finish gun or brad nailer and use the appropriate stainless steel nail, using 2 or 3 top and bottom.
Thank you both for your replies. I appreciate you taking the time to give suggestions/advice. Looks like I've got a lot more work to do!
