| I am converting my garage into a family room. I have an existing access panel for the garage attic. Problem is that it is located right next to where I want to install a ceiling fan. The fan blades will block the access panel, so I want to move the opening just enough to avoid the fan.
The current opening was made by cutting one 2x10 rafter, and heading it off. I have 2 choices. I can move my opening like 12 inches North, or like 32 inches West. I need your advice on what is more structurally sound. For the North option, I would stay in the same rafter bays. I would cut the same rafter another 12 inches or so, and put another header board across. For the West option, I would jump to a different set of bays. I would cut a new rafter, and add header boards across. Sturturally speaking, which is my better option? Cut the same rafter another 12 inches, or cut a new rafter? Thanks, Chris |
| If you frame it correctly, it doesn't matter where you put it. Ron |
- Posted by cloudcrasher (My Page) on Wed, Oct 22, 08 at 12:41
| I agree, either bay is fine. I would use joist brackets and double that header. Cut back 2 bays if a larger opening is more useful. No problems if done correctly |
