Fireplace insulation
Posted by newhomeowner-2009 (My Page) on
Thu, Oct 8, 09 at 13:11
I just had my fireplace chimney cleaned, and the repair guy suggested that I get a fireplace insert that can prevent a draft when I'm not using the fireplace. This is a good idea, so went over to Home Depot and they had no idea what I was talking about.
Online, all I could find was this, http://ucanhealth.com/local/merchandise/?pid=2576&ptt=Fireplace_Insula ting_Plug which looks to me like just an overpriced piece of styrofoam. If anyone has any suggestions, either homemade or commercial, I'm all ears.
RE: Fireplace insulation
A retrofit damper should be installed at the top of the chimney and requires a clay tile liner. It is operated from the side of the fire box by a cable.
They are sold through fireplace shops, chimney sweeps and Amazon.com.
Here is a link that might be useful: top damper
The chimney sweep recommended that too, but the price he quoted was $500. This, or something like it, seem slike a more economical way of doing the same task. I saw this on Amazon and I see it is theoretically available at Home Depot:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?stor eId=10051&productId=100662572&langId=-1&catalogId=10053&ci_src=1411094 4&ci_sku=100662572&cm_mmc=shopping-_-googlebase-_-D22X-_-100662572
If you put URL's in the box provided and give it a name, people can click on it.
Would you really take that thing out every time you wanted to use the fireplace? I suspect you will use it once and then throw it away because of the mess it makes or you'll try to start a fire and smoke up the house. Then you'll be back where you started.
If the chimney sweep wants to charge you $340 to attach a $160 damper to the top of the flue tile, you're talking to the wrong guy. Order the damper online and offer him or another chimney sweep $100 to install it.
All that is required is climbing up there with the damper unit and a tube of glue and sticking it on top of the clay flue tile and then dropping the cable down the chimney and securing a bracket to the side of the fire box.
Avoid temporary solutions to permanent problems.
Here is a link that might be useful: installation instructions
