chain saw
Posted by josh1 (My Page) on
Sun, Oct 4, 09 at 11:29
I have a McCullough 2.0 chain saw that has an automatic oiling system. When I put the chain saw in it's case after use, I find that the oil leaks out of the saw into the case. Any ideas as to what is wrong?
RE: chain saw
It's normal for a small amount of bar oil to leak out after use when stored as the oil collects around the rear sprocket/gear in the housing, and unless you immediately pull the cover and wipe it out, it will seep a little of what's been built up in there. If your leak is more than that and excessive, I would contact a McCullough dealer and get thei take on it as it could be a faulty seal.
