| Hi brickeye,
Yes I used it on some outside repair/patches last year. You said it's not for outside use in another post. Do you suppose it will start failing? I guess I thought I found something that was really good. I guess I should have looked at it closer. A 2 part epoxy probably would do better, or something not water based maybe. Darn! |
| It depends on how dry it stays. A couple coats of latex paint can exclude some moisture, but not all. I rarely use the epoxy fillers any more (used West systems for many years and still do when really needed) since after mixing you have to add a filler material. It got to be to much of a hassle to keep enough of everything around, and have to wait for delivery if a repair was larger than my stock. The Minwax is polystyrene monomer and catalyst, the same 'active ingredients' as Bondo car filler but with a softer (easier to sand) filler (talc). |
