| Just getting around to some home inspection report repairs.
One issue in the report dealt with a heal joint in the attic. It stated, "1) One of the rafters lacks a heal joint connection to the ceiling joist at the north side of the main attic area. It is recommended that solid blocking be installed. " Check the link below for a photo of the inspection report page that deals with this issue, photos of the actual issue and photos of possible repair scenarios.
Thanks for the advice. http://s1121.photobucket.com/albums/l511/jayherenow/heeljoint/ |
| The "problem" description and the pictures in your link don't correlate with my understanding of "heel joint", so I can't make any suggestions. Blocking will not do squat on a tension member, which is the joisting. Your home inspector has a lifetime's worth of overtime employment if these are the nits he picks...if it ain't broke don't fix it. There are cracked wood structurals around the world that came off the skid that way. On the other hand, the doubled and tripled members, what do they head off?
- Posted by jaysgarden (My Page) on Fri, Oct 7, 11 at 8:05
| That double is resting on a wall below and that triple kind of has something to do with a tray ceiling below. I attached a few more photos. I agree that the inspector's terminology of heel joint, where the double and triple terminate are wrong. I'm no framing carpenter but my search of the term heel joint mostly deals with trusses)where the top and bottom chord meet) Maybe my question should be is it improper the way this double and triple is terminated, without any connection(at the double and triple's end face) to another framing I have contacted the home inspector but he has not returned any messages. I added a few more photos. In the preface of the inspection report it states: Items noted for "Review/Repair as Needed" in black refers to a deferred maintenance condition and or component(s) or condition(s) that should be monitored with a possible need for future repairs. Items noted for "Review/Repair as Needed" in orange are considered to be a defect of functional concern The inspector refers to the term "heal joint" in two places on report page. Under the Orange Review Repair and under the black Review Repair I attached a photo of what I think he is referring to under the Orange section and I understand that. It is what he is referring to under the black section that is the topic of this post and is puzzling me. Thanks |
| Re: the double & triple header supporting the tray ceiling; they appear to be resting on something (photos 6&9 ), perhaps a wall at right angles running north/south? Further, there is a two stud post to the right of the triple (looking east). I am ASSUMING there is ample load bearing under this area. |
- Posted by jaysgarden (My Page) on Sat, Oct 8, 11 at 7:21
| Alphonse....I bought the house months ago and like I said I was just getting around to some of the inspection report issues. The inspector did say that what he sees in the attic is no big issue with only one twisted rafter and 2 that have cracks. He said he would be more concerned if there were like 10 rafters with cracks and a lot more that were twisted. But I'm a nit-picker. I think I'm just going to remedy the twisted rafter at the south side of the attic. I'll drill a hole thru rafter and joist and pull together with bolt? Been told to keep it high to not pull the drywall ceiling fastener to pop. |
| "I think I'm just going to remedy the twisted rafter at the south side of the attic. I'll drill a hole thru rafter and joist and pull together with bolt? Been told to keep it high to not pull the drywall ceiling fastener to pop." You could do that, and it's wise caution about drywall popping. But be careful where you put holes through joists/rafters. It appears that what the blocking alluded to by inspector in this case is between the pairs of rafters...compression elements that prevent twisting, just like X braces. A common strategy was to run a lengthwise member (2x) atop the joists and toenail the rafters. If you use blocking remember to allow airflow from soffit to ridge. |
- Posted by jaysgarden (My Page) on Tue, Oct 11, 11 at 9:38
| Alphonse...are you suggesting using blocking to fix the twisting rafter shown in picture 17? |
| I'm saying that's what I think the inspector meant, which I initially misunderstood. There are a number of ways to "fix" the issue. A c-clamp would work. So would the through bolt, just be careful where you put the hole. |
