| I just fixed a roof leak coming from a roof vent pipe sticking up from my kitchen and I began to wonder if bugs could use this pipe to enter my home. I live in Florida (bug heaven) and we recently had an infestation of roaches in the kitchen around the sink area.
In Florida you have to spray every month and I do that. We've never had a problem with roaches before. I have sprayed the kitchen repeatedly and I think I have licked them. But I after being up on the roof working on flashing around the kitchen vent pipe I began wondering. This pipe is near a nearly flat porch roof. When I was up there I found the porch roof littered with all kinds of leaves and little branches and I also found there were ants wandering around up there. Does the vent pipe have water in it that would block bugs from getting into my kitchen? Would anything happen if I rigged some screening to cover the opening of this roof vent? Thanks. |
| Let's clarify what your vent pipe does-is it a vent for your kitchen sink (plumbing), or some other vent-HVAC, dryer, etc.? Plumbing vents should NOT have water in them as their purpose is to prevent vacuuming the water seal out of sewer gas traps when flushing, draining etc. That liquid seal will prevent most insects from house entry. I say most since some larvae can hatch after being laid in such conditions. |
| Snakes, bugs and all manner of creatures can get it. I'd sleep with a gun on the nightstand. You will soon die. |
