| I tried to remove the caulk where the tub meets the tile, and it pulled out the grout with the caulk. I stopped after the first tile. This caulk isn't flexible, almost chips off and has somehow bonded to the grout. Is there some type of solvent that would soften the caulk while leaving the grout undamaged?
I would like to say that the previous owner did this caulking job, but it was me. Although it's been a couple of years, I thought the tube just said tub/shower caulking, but my goodness! Thanks for any sharing any advice or guidance. I hate it when what I think will be a relatively quick job turns into a learning experience. Cathy in SWPA |
| "I tried to remove the caulk where the tub meets the tile, and it pulled out the grout with the caulk." Was the grout between the tile and the tub? It never should have been there in the first place. Just pull it all out and put in new caulk. If the grout is between tiles, there is something wrong. |
- Posted by cathy_in_pa (My Page) on Wed, Sep 23, 09 at 4:54
| "Was the grout between the tile and the tub?" Yes, where the base of tile meets the tub. I wondered about that. I have limited experience, but can't recall ever seeing that before. Many thanks for the advice, Brickeyee. This is going to take more time than I anticipated. Take care -- Cathy
| Any grout between the tile and tub should be removed so pull it out with the old sealant and re seal the joint with the most expensive 100% silicone sealant you can find, not just tile and tub caulk. It is necessary to thoroughly remove all of the original silicone in order for the new silicone to stick. Unfortunately that is extremely difficult. Here are some suggestions from GE: "It is VERY difficult to remove silicone from a surface. However, if you must remove it, follow the suggestions below. * For ceramic tile, marble, Formica, fiberglass, etc., use 100% mineral spirits (turpentine) and a non-abrasive scouring pad. Test solvent on a hidden area of the surface to ensure that discoloration will not occur. If discoloration does occur, contact the manufacturer of the surface for further assistance. NOTE: For surfaces such as hard plastics or painted surfaces, including cars, use rubbing alcohol and a soft cloth. Do not use mineral spirits. Only use these solvents in a well-ventilated area and follow all safety precautions and instructions listed on the product label. Material Safety Data Sheets for GE Sealants & Adhesives products are available upon request. Similar information for solvents and other chemicals you choose to use with GE products should be obtained from your suppliers. When solvents are used, proper safety precautions must be observed. I suspect this is a far more difficult job than you yet realize. |
- Posted by cathy_in_pa (My Page) on Thu, Sep 24, 09 at 8:40
| Many thanks for the additional information, macv! In particular, instructions for what to use for each circumstance -- great! I was wondering about mineral spirits, except this bathroom has no ventilation except for a rinky-dink fan (add a teenager, hence the mold/mildew.) I ended up googling caulk solvents and found a 3M product that seemed to get good reviews and was recommended by Popular Mechanics in its How to Remove Caulk - 6 Easy Steps. I think I just used DAP kwik seal. I would really like to just remove the caulk as a first step and then check the grout. "I suspect this is a far more difficult job than you yet realize." Yep. While I thought I was mid-way on the caulk learning curve, I am at the high end knowing when to stop due to past screw-ups. Because it took me 15 minutes to remove about 3", I walked away and came here. Now, I'm at least committed to fixing. Whatever I do, is going to take more time than anticipated. Thanks again for the great additional information. I'll report back if I have any success. Take care - Cathy
| If it is DAP Kwikseal, it is not silicone sealant but an acrylic latex caulk with some silicone added to make it a bit more flexible and last longer. If it could originally be cleaned up with water and be painted, it doesn't contain much silicone and shouldn't be difficult to remove. If the product only lasted a few years I don't recommend using it again. The most flexible and longest lasting sealant is 100% GE silicone but it requires some skill and experience to install neatly. |
| "100% mineral spirits (turpentine)" Someone should tell DOW that mineral spirits and turpentine are NOT the same thing. Mineral spirits comes from distilling crude oil. |
- Posted by sierraeast (My Page) on Thu, Sep 24, 09 at 18:24
| Most flooring outfits have silicone caulks in a wide variety of colors where you can match up your existing grout with that of the colored silicone. Remove it all, clean it out and rid of any loose debris, find a matching colored silicone to go with your existing grout, no worries. I know easier said than doen, but persistence pays off. Never grout up to the tub, ever again. Hear me? Never again! The same applies to baseboard if your tile butts up against it, dont grout the joint between the tile and base, but rather use matching colored silicone. |
| i would like to know why the caulk that you put around the tub turns "dirty" looking in a matter of weeks after you put it on. it is regular tub tile but it is just awful looking. a oerson could do every couple of months. any suggestions on how clean it or a different product to use? thanks in advance. |
