| I have a Craftsman garage door opener, model # 139.53674SRT2. Even with new batteries the remotes no longer work. The door control & the keyless entry work just fine. I tried the troubleshooting tip in the instruction booklet (pushing the learn button on opener panel) but to no avail. Any suggestions? Thanks. |
- Posted by don_1_2006 (My Page) on Tue, Sep 11, 07 at 13:38
| Did you try reprogramming the remotes or just push the learn button? Odd for both remotes to quit. Did they quit at the same time? |
- Posted by don_1_2006 (My Page) on Tue, Sep 11, 07 at 13:41
| An afterthought. Make sure the lock has not been turned on at the wall control. If the light in the wall control is blinking press and hold the lock button for 6 seconds. This will turn off the lock function. |
| Thanks Don, I appreciate your response. The two remotes did not go out at the same time. Ones been dead for probably a year or so & the other one went out last week. I tried to reprogram the remote by following the instructions on opener. I held the remote button while I pushed & released the learn button. My wall control only has one button. The green light has not been blinking - just a staedy light. Thanks. |
- Posted by don_1_2006 (My Page) on Tue, Sep 11, 07 at 17:32
| The fact that your keypad works proves your logic board is o.k. I think you have just had bad luck with your remotes. I would purchase a new one. Just make sure it is the same as your old ones so there is no problem there. |
| Thanks Don. I'll give that a try. |
| I have a Craftsman GDO Part# 41A3625 I lost both of the original remotes and I bought two of the generic universal ones from Lowes. When I program them they seem to work fine. An hour or so after the remotes no longer worked. Could it have anything to do with heat because it was about 98 to 100 degrees when I was doing this? Also my door started magically opening in the middle of the night. Any suggestions. Thanks |
| Don, The local Sears store has been out of my remote for a couple of weeks but got some in today. I went & picked one up & my garage door opener is working like a charm. Just wanted to say thanks for the tip. $40 for a new remote is a lot cheaper than a new opener (and a lot less hassle) Thanks. |
| Hey, Don. Hope you are still around. You seem to know what you are talking about. I just purchased a home that has a Craftsman GDO. During our last inspection of the house prior to purchase, there were two GDO remotes on the counter. After closing, the remotes were gone. The opener was manufactured 10/00 and is model # 139.53975SRT1. Went to Home Depot the other night and purchased a Chamberlain universal system (a wall unit that plugs into a wall outlet and rewired through the attic to the GDO) with two remotes. After wiring it, and after hitting the "smart button," I could only get my GD to move an inch before returning to the starting position and stopping. Gave up on that system after reading some old posts on this website. Went to Sears today and the salesman ran my model number through his computer and said that it has a new model number or something like that. He then grabbed a couple of remotes from the shelf and told me that reprogramming would be a breeze. Well, I got absolutely no response from my GDO. Any suggestions? Please help. |
| I am having a problem with my Craftman garage door opener Model 41A4315-7D. We were trying to change the password and somehow we disabled both the garage door openers and the keypad isn't changed. How do I find directions to changing the password and enabling my remote? Thanks Lynda Skluzak |
- Posted by don_1_2006 (My Page) on Thu, Oct 4, 07 at 17:01
| On the back of your motor unit near where all those white wires go you will find the smart/learn button. I think you have already found it but--- Press and immediately release it and then key in any 4 digit code you want and press enter. The instructions for the remotes are: Press and hold the button on the remote and then press and immediately release the smart/learn button. Do this for each remote. Follow these instructions and you should be set. The key in both cases is to immediately release the smart/learn button. If you hold it in you will erase the memory and get no where. Wouldn't hurt to keep a copy. |
| Everytime I open the garage door it stops about one foot high from the floor, I have to repeat about 4 times to get the door opened in full, the censors are ok, what should I do ? Any advice will be very helpful. |
- Posted by don_1_2006 (My Page) on Fri, Jan 4, 08 at 16:30
| On the rear of your opener near where all those white wires go you will find the 'up force' control. Turn this control about 1/4 turn. You also need to take the cover off and check the condition of the drive gear. It is a white nylon gear just in front of the motor. |
| Thanks Don. I had the same problem and now problem is solved. |
- Posted by dangardner (My Page) on Mon, Jan 7, 08 at 19:40
| I have a Craftsman 1/2HP 139.18850 (Nov.1995) that has been working flawlessly for 12 years now. Just today it stopped. When pressing the wall button or outside keypad the motor (41A4315-7C) hums twice and does nothing. The green light up on the motor blinks 5 times, stops, blinks 5 times and so on. I've opened it up the motor housing to find a mess of white plastic dust. The door moves easily up and down manually. If the gear was stripped would I not still see it attempt to turn? With the cover off I see no movement at all, just hear the motor hum and that's it. Any help is much appreciated. |
- Posted by don_1_2006 (My Page) on Tue, Jan 8, 08 at 12:00
| The white plastic dust you are seeing is the drive gear being slowly eaten away. It could be jammed causing the motor to just hum. The LED is blinking the code for "RPM sensor or motor overload" which makes sense. |
- Posted by dangardner (My Page) on Tue, Jan 8, 08 at 13:15
| Thanks Don - I'm glad I found this forum since I have no manual or GDO experience... Any way to 'unjam' the gear or should I just look into replacement as per a bunch of other posts? |
- Posted by don_1_2006 (My Page) on Wed, Jan 9, 08 at 10:23
| You will need to replace that gear. The part number is 41A2817 and is available from Sears with a complete set of instructions. |
- Posted by Mister_MT(markthrondson@yahoo.com) onSun, Apr 6, 08 at 20:07
| Hi Don, I have the exact same issue and model # as the earlier post I've copied below, and didn't see a response. Our old remote units were simply wearing out, so we thought we'd get "sophisticated" and go with one of the learning remotes. The learning feature works fine with the remote and the GDO, but we started seeing the GDO magically opening up quite frequently, either on its own or because it's now got a code that matches a neighbors unit. We have tried over 10 different code combinations and have seen exactly the same issue. Is there any way to reset the GDO back to it's original code, and determine what that setting was? There are no switches accessible on the exterior of the unit, and we actually switched the old Craftman remotes to the new code that we set the smart remote to in order to make use of them. Thx in advance. ****************************************** * Posted by kes3 (My Page) on I have a Craftsman GDO Part# 41A3625 I lost both of the original remotes and I bought two of the generic universal ones from Lowes. When I program them they seem to work fine. An hour or so after the remotes no longer worked. Could it have anything to do with heat because it was about 98 to 100 degrees when I was doing this? Also my door started magically opening in the middle of the night. Any suggestions. Thanks |
| Never mind - found the owner's manual on sears.com after I found the sears model #. It was easy to solve once I had the manual. FYI, for anyone else - set the older remotes to whatever code you want (switch 1 should be neutral, other 8 can be any combo), then push the SR (smart remote) button on the GDO and release. Push the button on the remote you want to use, and it should open the door. It's now set to that code. |
| Hi Don, I just bought a house with a Craftsman 3/4hp GDO and there is no manual for the unit from the previous owner and I'm having issues with the remotes, the keypad and the wall unit. Here's a summary of the issues: When I press the wall unit: the garage will move a few inches, retract and the lights will blink 11 times. If I hold the wall unit button down, the garage will go down as long as I hold the button down, then retract. If I hold the button down until the door gets to the floor, it will then stay shut, but only if I hold it until is closes completely. When I press the remote button: the lights blink 11 times, no action from the door. As for the keypad: I followed your instructions above re: changing the code, and I can't tell if it works. Once I submit my 4 digit code am I supposed to press # or * or 'enter'? Nothing is working. As well, I have followed your instructions above for changing the code and resetting the remotes, to no avail. Thanks in advance. Joe |
- Posted by don_1_2006 (My Page) on Wed, Apr 16, 08 at 18:49
| The main problem you are having is with the sensors in the doorway. Make sure these are pointed at one another. If they are pointed correctly each should have a small light that is lit. If the light doesn't come on you have either a bad sensor or bad wiring to the sensors. After pressing the smart/learn button and entering your 4 digit code you should press enter on the keypad. |
| I have a 41A3625 1/3 HP 20+ yrs old that stopped working today. Door was open and motor just hummed. Manually closed door. Trolley just sits there and motor hums, then stops, then hums what sounds like reverse then stops. Any suggestions? |
- Posted by don_1_2006 (My Page) on Wed, Mar 11, 09 at 9:22
| See if the trolley is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is down and then locate and adjust the 'up limit' control. It is on the side of the motor unit and you need to turn it 2 or 3 turns in the opposite direction of the arrow printed on the cover. |
| Can't find any bolt. tried turning the up limit control with no result. have the door down manually already. other options? |
- Posted by Rena h(Renaboop@hotmail.com) onTue, Dec 28, 10 at 23:43
| We recently rented a condo and only has one garage door opener.. We purchased a universal remote frm home depot programmed it fine and then ended up with other peoples garage door openers being able to work ours..how do we rest the system..we have tried pressing the rest button a Number of times..please help.. |
| Rena: You need to post the make and model number of the opener (it should be on the unit itself). Also you should post the brand and model of the universal remote you purchased. |
