Gluing Foam
Posted by johnc777 (My Page) on
Tue, Sep 25, 12 at 8:42
I need to fill a hole in a fiberglass/foam filled entry door. I changed out the lock and there's about a 3/8" hole left from where the old handle attached. I want to fill it and put a little brass plate over it.
I though about filling the hole with a 3/8" dowel but don't know what glue to use that would stick to the foam. This is nothing structural, just decorative.
RE: Gluing Foam
I'd put a dab of paintable caulk in it.
RE: Gluing Foam
I need to fill the hole with something solid so I can screw into it to attach the brass plate. I figured a dowel would be a good choice but I'm not quite sure how to keep it in place while I drive a screw into it.
And I can't use any kind of anchor that sits proud of the surface (like the lip that's on a plastic anchor) because the design of the plate is such that it needs to sit flat.
RE: Gluing Foam
So the screw won't need much holding power afterward? Pack it with toothpicks, break off flush.
RE: Gluing Foam
How about using a brass plate and attaching it with glue?
RE: Gluing Foam
Is the hole only one one side of the door?
Can you use a molly bolt? You could use a brass screw into the molly so it matches your brass plate.
RE: Gluing Foam
Push the dowel in with construction glue, PVA or even caulk, and let it set. Then you should be able to screw into it.
