| I used to clean my gutters myself twice a year, but we built a new house and now the gutters are just too high for me to take care of comfortably. I just paid someone $90 to clean them. After reading the posts on here I got a quote from someone to install Leaf Relief, they quoted me $780 to install them, which is $5.50 per foot. So I am thinking that means that based on two cleanings a year at $90 per cleaning, it will take me 4 and a half years for the investment in Leaf Relief to pay off. That of course is on the assumption that they work. I am curious what others think of that idea and of the Leaf Relief product also. Thanks. |
| Amlar, There use to be a detailed thread about Leaf Relief and other systems. I found the old thread cached on a search. I thought this thread might help you learn about Leaf Relief and other systems. Gutter Protection Systems I saw a forum posted about gutter helmet and leafguard. I have heard good and bad stories. I am seriously considering purchasing a new product called leafilter. It is a vinyl product with a stainless steel filter that keeps everything out of your gutters, even sand and shingle grit can't get in. Anyway, the price was less that the other 2 companies and it seems like it will solve my gutter cleaning problem. I want to know peoples experiences with leafilter, gutter helmet, or leafguard as far as price and/or performance. RE: Gutter Protection Systems In my opinion.....having seen lots of them and talked to people that have them, they don't work as advertised. I plan to use a system called Rainhandler. Have never used it myself, but have seen it on a few houses in the neighborhood and stopped to ask one person about her house and saw it, and they love it. She said her builder uses it on most of his houses. That's good enough for me. RE: Gutter Protection Systems I have Rainhandlers; be aware that they're not the answer to everything. It's true you don't have to clean them; I have trees over my house that drop tons of flowers, nuts, etc., so the gutters were always full of something. The stuff doesn't stick in the rainhandlers much. However... they don't spread water out as much as the ads would have you believe; if you have drainage problems caused by water getting into your basement by the house wall you'd probably be better off with gutters. And I've heard that you shouldn't put them where the water splashes down on concrete, although that's not a problem I have. And if the roof is over a doorway you have to glue a diverter to your shingles. And they're not cheap. I didn't really research the gutter helmets, etc, but I remember reading that thread too, and it sounded like they didn't work nearly as well as advertised, either. WW RE: Gutter Protection Systems You may want to check the building codes in your area. Some city's might not allow a system like rain handler to be installed if your roof water is not diverted into a storm drain. RE: Gutter Protection Systems No codes here to worry about w/that. I agree, you do have to pay attention to where the water goes and I plan to. RE: Gutter Protection Systems We had the LeafGuard brand on our old house, and absolutely loved them. (We will be putting them on the new house, also). The LeafGuard is a single piece that attaches where the normal gutter goes (they make them on site to fit your house), so there are no pieces jammed up under the shingles to create ice-dams or mess with the waterproofing. Worth looking into!
RE: Gutter Protection Systems We used the cheap rolls of plastic mesh. They have worked well for 3 years. When I replace the dented rusted metal gutters with plastic, I will probably use the matching snap-in plastic grids similar to the plastic mesh. RE: Gutter Protection Systems After reading through that other, long thread on gutter guards, I've pretty much decided against any of the gutter protection systems based on surface adhesion. My dad just bought the Waterfall for his home and likes it okay, but we have a lot of pine needles and smaller debris that fall all over our yard and into our gutters, so I think those gutter guards would be almost worthless for us. The first one was mentioned on that other thread, but not much comment was made about it. The 3rd one seemed to have a few good reviews: 1) GutterFilter (www.gutterfilter.net) Thanks for any input on these. RE: Gutter Protection Systems #2 I just realized the first post in this thread started out asking about Leaffilter (#3 on my list above). I can't really tell if MrHab's response to it was specifically concerning the Leaffilter or just gutter guards in general. The other thread did seem to give a somewhat negative opinion of gutter guards generally, but it did not answer the question about these alternative systems (in my opinion). And I haven't been able to find any solid reviews of these anywhere on the net. Are they just too new? RE: Gutter Protection Systems crboone, we have over 100 jobs of leaf relief installed on homes in Cincinnati and have had no problems, even with folks that have pine needles. I recommend this product to all my customers. I would imagine your costs would be significantly less than the other products too. RE: Gutter Protection Systems Thanks, John. If you have any comments or insights to add to the below, please do. I'm receiving information from the other 4 vendors as well: Swistun replied that they are coming out with a better product that's easier to install in 2 months, but I really don't want to wait that long if I can help it. Leaf Solution *is* installed under the first shingle, and their installation video appears to show that it has to be nailed or pinned into its gutter clamp or frame (installation professionals may correct me if I'm seeing this wrong). I'd rather not have to go under the shingle if possible, but it appears to be the best way to get a sloping guard so that more debris actually falls off the gutter instead of piling up on top of the guard. Funny, but they have a video touting how easy the guard is to install, yet their warranty requires that an authorized, trained dealer do the installation. If you have your roof redone, the dealer has to come out, uninstall the guard, then reinstall it once the roof is done or your warranty is void. I need someone to install it anyway, but what's the point in showing how easy it is to install if only you can do it? Gutter Filter does not have any installers in my area, but it appears to be so easy to install that almost anyone can do it quickly. They also have a lengthy 20-yr warranty regardless of who installs. The only disadvantages I've seen mentioned were from the Leaffilter site (a competitor), which said the foam can become clogged with oils, shingle grit, etc. so that it eventually does block the flow of water. I'd like to know if this is really true since they have such a long warranty. Gutter Filter also does not slope so debris will collect on top of it more readily. I'm looking carefully at Leaffilter. They have a lifetime warranty, requiring a dealer install. I found a link with much better photos than their own website: http://www.leaffiltersouth.com/My_Homepage_Files/Page1.html They really ought to have this link on their site, because the photos on the site are terrible in my opinion (as of the date of this post). This guard is not installed underneath the shingle yet appears to have a gentle slope. See: http://www.abc-siding.com/leafilter.htm They will actually refund the material cost of the guard (not the installation, of course) if your gutters ever clog. Pretty audacious. I'm posting all this since I've had such difficulty finding any independent reviews for these particular products on the internet. Hopefully some search engines will pick this up so it might benefit others. Of course, these comments are just my personal observations at this point. :) RE: Gutter Protection Systems Just a few things to add crboone: If Leaf Solution installs under the shingle, this would be one reason I wouldn't have it installed, just in case my roof ever needed replaced (Alcoa's Leaf Relief does not install under shingle). Although Alcoa's warranty is only for a period of 10 years, their brochure states that Leaf Relief Never clogs and Never overflows. I'm not sure where you read that you need to clear off Leaf Relief but that would only apply to an area blocked by wind possibly. Gutter Filter uses the same type of polyurethane filter that we do in our gutter protection systems. We have never had a problem with the polyurethane clogging. The polyurethane that Gutter Filter has is very pourous and shingle grit is to large to pass through. We use to be a Leaf Filter dealer but discontinued do to a few problems. Fyi we had a problem with their nylon filter deteriorating after about a year. I don't know if they have corrected this problem but if you get a chance to see a sample of their product, pay close attention to the filter itself (the nylon above the rubber membrane). If they nylon appears fragile or appears as though it may rip easily then they may not have changed their filtering system. My guess is you are probably going to pay double or more for their system vs. Leaf Relief too. We have been in the business since 1991 so we have had experience with many systems. RE: Gutter Protection Systems Thank you for that valuable information. I didn't do my homework on the cost, and sure enough Leaffilter is quite expensive ($14-18/ft per the website). I had scheduled for a dealer to come out and give me an estimate, but I may cancel it now at that rate. If Leaf Relief is that much cheaper, then the shorter warranty may not make that much of a difference. If they have a dealer in my area (NC) I may plan to get an estimate. Their Adobe FAQ is what mentions having to clear away certain areas -- where there is little wind, like you mentioned. But the cost factor might narrow the field to Leaf Relief and Gutter Filter for me. More info on Leaf Solution: Their website says it depends upon your roof whether or not they install under the bottom shingle. They also have hidden brackets that allow for installation in the gutter w/out going under the shingle. But it's not listed as an option, so my impression is that's only for certain roofs. But does this really matter? It looks like it just slides under the shingle and that's it. Their installation gallery is worthless, though. They just have three photos of nice homes -- you can't actually see the gutter guard on them at all. For all I know they just took some pictures out of a real estate magazine and posted them on the website. On the technical specs page, they say that the "expanded aluminum" lasts for 20 years, giving the impression that the guards will last that long. But farther down they indicate the filter membrane will last for only 10 years. Then, the warranty page says 10 years. So their warranty is also 10 years like that of Leaf Relief (although a few statements in their warranty seem a little odd to me). I have no idea what the cost/ft is for this product. This is just a humorous aside. I went to a home improvement show in Greensboro, NC on Saturday, and at least 5 different reverse curve gutter guard companies were represented. Every one of them had the same display with their gutter guard atop a section of gutter installed on a makeshift roof with water freely flowing off the roof and into the gutter. But guess what? No debris and no leaves were added to show how effective they were at keeping them out! Just nice smooth water that you could almost use as a waterfall display in your foyer. I would have liked to drop a handful of debris on top of them to see what would happen. RE: Gutter Protection Systems crboone, I applaud you for doing your due dilegence, it will pay off. I see so many other homeowners getting ripped off. I don't know much about Leaf Solution other than what I have seen on their web site. I do have a sample of Gutter Filter, I keep it out on my deck for testing purposes. Other advantages to Leaf Relief vs. other reverse curve products, I tell my customers are: that you shouldn't experience icecicle problems like you would with a reverse curve product (creating slippery spots on driveways and sidewalks) and you can't see Leaf Relief from the ground which preserves curb appeal. If you decide to have someone come out and show you Leaf Relief, you could go to Siding suppliers in your Yellow pages and find an Alcoa supplier, I'm sure they would recommend a reputable company to intall Leaf Relief for you. RE: Gutter Protection Systems Yes, the best way to find the most satisfactory product at a reasonable cost given the debris that clogs my gutters is to become as informed as possible. I'm leery about purchasing something on little information. When I saw my gutters crammed with pine needles and other non-leaf debris, I was suspect of the reverse-curve designs. Reading the experiences of others appears to support that. It seems like *all* of the designs have at least one possible disadvantage, but the negatives to some of the products are such that they negate the reason for installing them in the first place (ie. an exhorbitant cost for a gutter guard that's difficult/costly to remove in order to clean the gutter because the guard did not perform its function). This has led some to conclude it's better just to pay a nominal fee 1-3 times a year to have the gutters unclogged rather than purchasing the guards. The only solution is to find a truly effective guard at a lower cost. Since you pointed out the cost for Leaffilter, I'm suspicious that they are in the same mark-up market as the ineffective reverse-curve designs -- even if they might work better. Their site is hyped like the others as well. I'd be more apt to just have my gutters cleaned periodically than to pay such a high price. As to Leaf Solution, I have a few bad vibes from reading their website which have not been offset by any good reviews from customers. I don't believe I can trust the salesman to ease them. :) Showing expensive houses on their installation page without being able to see the guards really bothers me. I guess it boils down to this: sort through all the hype and show and get to the brass tacks. One other product I didn't mention previously is one that a friend of mine uses. He said he installed one of the Brookstone gutter guards several years ago, and he recently checked his gutters (while painting and preparing his house to sell) and found them to be clear. So, that's one more I will look into before I make my final decision. Well, I guess I've sorta taken over this thread from the original poster -- I have no idea whether this dialog has been helpful for him or not. Hopefully it will be a catalyst for others to do their own research at least. RE: Gutter Protection Systems I think your questions and your analysis have been very helpful. I did a lot of research a few months back and came to the same conclusions that you have come to. I even had John Allen out to give me a bid for the Alcoa product (he happens to be close to me) and if I can finally convince my wife to do it, I would still like to have him out to put the LeafRelief product on my house. I like having the Alcoa name on the product because I know that they'll be around years from now if I ever need service and the price seems more reasonable considering the cost of materials/installation. But, your problem is the same as mine--it's two stories up and I don't want to be on the roof in the first place, so it doesn't matter if I'm brushing off the top or scooping out the gutter. My question is this: does anyone know of a telescoping broom type of product that would allow you to brush off the top of those guards from ground level? The whole gutter guard thing is a real conundrum. After all, gutters are there to "catch" something... I think that no matter how hard you try or how much money you spend, you're going to catch more than water in the gutter. RE: Gutter Protection Systems The Leaf Relief installer called in response to my filling out the form on the Alcoa website. He said he charges $4/ft, installed, for the product. When John Allen said above, "My guess is you are probably going to pay double or more for their system vs. Leaf Relief," looks like the "or more" was right. At $14-18 per foot, Leaffilter costs more than 3-4 times as much. At $4 per foot installed, I doubt the Gutter Filter foam would cost much less. I believe it was around $2.50 per foot for a DIY installation. The 2 Brookstone products are about $1 to $1.25 per foot, so they would be even cheaper. However, one of those models is simply a reverse-curve design. It turns out that's the one my friend has, so he must not have the same problem with smaller debris since his gutters are clean. (The other model is plastic or vinyl with holes and a mesh screen covering the holes -- another filter type). However, I mention it because Brookstone's reverse-curve model is effectively the same (or similar) to the other systems, and yet it's barely over a buck per foot. Hmmmm. Talk about mark-up on the others! Anyway, it appears I'll be going with Leaf Relief. So thank you, John, for your input -- you saved me from having the coronary I would have had if the Leaffilter dealer had given me an estimate without my knowing the cost! A coworker is now considering the Gutter Filter for his house because he can install it himself fairly easily. By the way, the contractor I spoke to had switched from Waterfall to Leaf Relief. He said he hasn't gotten any callbacks on it yet. That's a good idea about the telescoping broom -- I'll check and see if I can find anything like that. But, I'd wait to see if I need it before I bought it. :) RE: Gutter Protection Systems Crboone, keep us posted on the performance of the product after you have it installed. I'm still waiting for someone to complain, I haven't had anyone yet (not to say that someone won't). If I come across a telescoping broom I'll post the link. RE: Gutter Protection Systems Ok, I will. It may be awhile before the real test comes -- my entire back yard was covered with pine needles sometime last fall. I had to mow them into lines and then rake them up, there were so many. If this thread fills up I'll start another one to post the results. RE: Gutter Protection Systems For that telescoping broom, how about a swimming pool brush? That's the best I could come up with... RE: Gutter Protection Systems That might work. But a broom reaching 2-3 stories might be unwieldy unless it were extremely lightweight. RE: Gutter Protection Systems Just an FYI -- they're supposed to install Leaf Relief today. They had another job close by this am. RE: Gutter Protection Systems Good for you Crboone. I want to stand corrected on the Leaf Filter system. I had an appointment with a homeowner tonight, Leaf Filter had been their just before me. Apparently Leaf Filter has changed their nylon filter to a stainless steel filter. I'm glad to hear this since we were having problems with the nylon. I still don't think that the price that Leaf Filter dealers are charging is justified. They can advertise that even a grain of shingle grit won't enter your gutter but shingle grit is not what clogs your gutters, leaves, twigs, pine needles, and small debris do. That's all I have to add, good luck with your system. RE: Gutter Protection Systems Maybe *they* felt justified in charging that price by at least giving better quality filter material. ;) RE: Gutter Protection Systems Well, Leaf Relief was installed today (a day later than originally planned). Another benefit of the Leaf Relief, I found, is that it looks classier than the others if there happens to be some guttering that you can see from the window, which I happen to have in a couple of places. My house is a brick colonial so it looks nice. Should I ever need to sell the house, it should make a good selling point. If I had a digital camera I'd post the photos somewhere! I'll post more updates as they come. RE: Gutter Protection Systems Here is a link to a gutter cleaning tool you can use from the ground that some of you were looking for, the pole isn't included but it gives you suggestions on where to buy them. According to this site you can clean your gutters as high as two stories. It only comes with 12' of rope, so I would imagine you would have to add more rope to the existing rope to reach two stories. I would think this tool would be ideal for any of those that have Leaf Relief and are concerned about any debris resting on top. Here is a link that might be useful: Gutter Sense ---------------------------------------------------------------------- ---------- RE: Gutter Protection Systems Thanks for the link, John. I'll check it out. RE: Gutter Protection Systems There is also another website that has a do it yourself product for under $1.50/ft to include delivery. Easy to install. The website is http://www.gutterguard.com Here is a link that might be useful: Gutter Guards- Do it yourself ---------------------------------------------------------------------- ---------- RE: Gutter Protection Systems Thanks for this thread and all the research. I too have been searching and researching and couldn't find definitive answers to whether these gutter guards work. I also have a very tall 3 story house on a slope, surrounded by trees, so there's no way we are getting on the roof to clean our own gutters.
RE: Gutter Protection Systems We've had a few heavy rains so far. I believe I mentioned this before, but there's a sloping roof that extends below our MBR window which terminates at a section of gutter, so I have a bird's-eye view of a small section (maybe 6-8') with the guard on it there. This section had a lot of pine needles in it prior to installation, so it's a good testing point. During a rain recently, some heavy water ran down the roof onto the gutter -- one side seemed particularly heavy. But I didn't notice any water careening over the edge of the gutter. I really need to go outside next time to view it from there to know for sure. It seems fairly certain (and obvious) that debris will accumulate on this guard as long as there are no days windy enough to clear it off. But once the winds come they might clear the guards in quick order. Whether or not the debris will cause problems, for how long, and whether it can become so heavy that most typical winds cannot clear it all off remains to be seen. In the Fall, when it practically "rains" pine needles here, I'll see if the debris overwhelms the guard and needs to be cleared off by hand. I hope it doesn't since most of the guttering is too high for me to reach, but that would still be better than clogging the gutter itself. Still, that might dissuade some from purchasing this product if they want a guard that stays clear on top if it also keeps the gutters clear and is reasonably priced. I'll do my best to keep you updated on my personal experience with Leaf Relief. - Ryan RE: Gutter Protection Systems I contacted Alcoa thru their website and had a guy over for an estimate. I contacted them specifically about Leaf Relieve. Instead of Leaf Relief, the contractor showed me "their" gutter system, Gutter Cap. I guess the lesson is to be specific in what you want, and if they don't have it, don't waste your time. Their gutter system was the most expensive I had to date, and I still haven't seen Leaf Relief! RE: Gutter Protection Systems If anyone needs a decent internet view of the Leaf Relief product you can visit www.alu-rex.com RE: Gutter Protection Systems I had horrible gutter problems (and then a wet basement) from a maple tree that dumped 3 times a year, first seeds, then stems, and finally leaves in the fall. I went the low cost route with those 4 ft plastic covers from HD about 50 cents per foot ... has worked great for 3 years! ... no clogs and no cleaning! RE: Gutter Protection Systems I installed GutterStuff on my house last fall and was so impressed with it that I became a distributor of the product. The product is terrific and can be installed by the local homeowner or by contractor. Marty Swift Here is a link that might be useful: http://Gutterfoam.com ---------------------------------------------------------------------- ---------- RE: Gutter Protection Systems I have huge oak trees along with birch, crabapple, etc. We love the shade, but it does come at a price. I had wire screens on my gutters and they were worthless. Just pulled them all off and pitched them and am actively seeking something better. Had Gutter Helmet come out today for an estimate. Not cheap, but it appears they stand behind their stuff. The most appealing feature to my currently uninformed mind is the fact that the forward lip of the "reverse curve" extends beyond the lip of the gutter seemingly making it very difficult for debris of any significant amount to make it inot the gutter. I need to do something soon as I don't want to have to clean the gutters again, ever! Please advise on any disadvantages or bad press of Gutter Helmet specifically or of the solid/reverse curve gutter protection systems. Meanwhile, after reading all the i9nformation in this Great Forum, I'll be researching the other products listed here as well. RE: Gutter Protection Systems Randbrag...I just received an estimate on the gutter helmet system as well. It was running about $18.00 - $20.00 per foot. I liked what I saw and it seems as if the system makes sense. It might be tough to justify the price since it is almost double the competition...but the product appears to be double the product of the competition as well. I was concerned about curb-appeal but went to several houses in the area with the helmet. It looked fine. I plan on ringing a few doorbells to see if the homeowners agree with the sales guy. RE: Gutter Protection Systems Randbrag, last time I checked, the gutter helmet does require some maintenance. I've read in their literature that you must spray the nose of the helmet occasionally to keep it functioning properly. If you do not keep the nose clean, the helmet may malfunction allowing debri to enter your gutter. RE: Gutter Protection Systems Hi, all. I'm new and was very interested in all of your posts to this thread. This is a mixed message so forgive me if I am posting a hybrid incorrectly. I'm hoping someone can advise which, if any of the leaf guard systems would be better for my own situation, as well as any gutter recommendations: Maples, elms, so lots of whirligigs and seeds,and shingle grit, not to mention leaves. The current old-type screen is lousy. My house is 1 1/2 stories, and there are only two places where the gutter is fairly difficult to access except by a tall ext. ladder. My roof is steeply pitched in two places, with valleys on each. Only the front one is a problem. Some people who have looked at this (when they show up that is) say the valley is the cause (the water overrun did not occur when I first bought the house), and I should put in some type of strip to divert it which I think would make it run off the side instead of into the gutter. I think the gutter needs replacing, unfortunately. It is not sloping correctly in spots, and seems to have pulled away since water runs behind it down to my porch (who knows what it has done to the wood under my siding). I also noticed that the holes into the downspouts are sticking up, and leaving water standing in the gutter even when it is sloped correctly (trying to hammer into place doesn't help). Thanks. RE: Gutter Protection Systems Hello Korat, You were asking how much water flow some of the gutter protection products handle. I know Leaf Relief has been tested, and will handle up to 301" of water per hour based on a 20' run ( I know that is an enormous amount of water but that is how much it will handle). I'm not sure about the other systems. A couple of divertors in your valley could slow the water down to help eliminate the overflow problem. If you are considering Leaf Relief as one of your choices for gutter protection you may still have to clean out your inside corners occasionally and any other areas that doesn't get much wind. If water is leaking behind your gutter you may want to find out if you have a gutter apron / drip edge / or flashing installed (a 2"x3" gutter apron is recommended). Most aluminum gutters (k style) are designed with the back higher than the front, so if there are any overflows water will spill over the front of the gutter not the back. For the money I would upgrade to a 6" gutter it usually doesn't cost that much more than a 5" gutter, roughly a dollar more per foot installed would be my guess. I would also insist on hidden hangers with screws (at every rafter tail or truss) so you don't have to worry about hammering in those nails anymore. Hope this helps. RE: Gutter Protection Systems Acerchio: No, I've not heard anything really negative towrd the gutter helmet (GH) in particular. I've read hear and there where folks say that no system is perfect, that GH is too expensive, etc. The logic behind the design of the reverse curve (RC) systems like GH seems reasonable, i.e. surface tension. I'm concerned about runoff, though the fact that the GH design is one of the few RC designs that actually extends beyond the forward edge of the gutter making it nearly impossible for solids to enter. I like that, but that feature could also lend itself to possible runoff issues. The money is a thing, but if the GH or something else works like it claims it does and I don't have to fight the tree debris any longer, its a good investment for me. RE: Gutter Protection Systems Does anyone have any experience to GutterDirect.com's Leaf Pro MX. Its a reverse curve system that appears to run about $3/ft. and carries a non-prorated, transferable, lifetime warranty. (I just requested a copy of the warranty to review the "fine print"). The design seems sound, but I was wondering if anyone has it installed or knows of those that might. RE: Gutter Protection Systems John, thank you so much for your prompt reply, and it does help. I have called a couple of people to get estimates, so it gives me a little more knowledge during the discussions. It's a pretty big, steep roof. Wish I could draw a picture on the message board, I'd show you! How can I describe this? Looking at the front of the house, the right side of the roof is kind of like an A-frame, i.e. it goes up to a high point from front to back (the 1/2 story part), and no gutter. From the end of that to where the roof over the porch starts is 11.6' (a gutter extends for a part of that). The rest of the roof (behind the porch) is not as tall, dissecting the high part in the middle and running from side to side. The offending valley is at the intersection of the two main roof sections on the front, where the roof over my front porch starts, which slopes out from the horizontal roof (the back valley is steep,too, but not a problem). The porch gutter is 8.2' across the front of the porch. The porch extends out from the main part of the house 8.1', but not as far out as the A-frame part. The lower roof from the end of the house to the intersection is 30.3'. Does that make it any clearer? Only if you wouldn't object, I could send you a picture, since it's hard to describe. This problem has only occurred in the more recent past, so the overflow may be due more to the gutter's fault than the roof's, but both may be to blame. The gutters don't appear to have a higher back - I have no idea how old they are. I appreciate your sound advice. Would the diverter possibly cause water to go off the side of the porch down to my foundation? RE: Gutter Protection Systems A couple of points I'd like to add to what I've read here while I am also shopping for gutter guards: 2) This was pointed out, but bares emphasis. My understanding is that all of the systems will eventually need maintenance. You ought to plan to check your gutters at least every 5 years if you have some kind of gutter guards. If not more often than that. When you're buying you need to consider whether the ones that are guaranteed for life aren't going to end up costing you more than the yearly or bi-yearly maintenance you would have needed without them. For instance, Gutter Helmet may be guaranteed for life, but you do pay for that guarantee, and you should consider whether its worth it. I read on another website that ones like this are hard to maintain if you have to. 3) There are many competing brands out there. The list is very long and prices vary. There are a few popular brands that haven't been mentioned here yet. For instance one my neighbor has is Gutter Tunnel which is completely hidden from view. They haven't had it long enough to say much about it, but it looks like so far, so good. That one uses two screens or filters inside the gutter. The logic seems sound. RE: Gutter Protection Systems I have been trying to decide which way to go on my gutters. I am leaning to LeafGuard because of their cleanout warranty. They will clean the gutters if they ever clog. I know someone who has had the local company do this because they have a lot of pine trees, as do I. This warranty is also transferable (for $100), which would make it a great selling point for the house. RE: Gutter Protection Systems Pete,
RE: Gutter Protection Systems Thanks crboone, What would be a cheaper, but still effective solution in my case. I am open to all ideas. Thanks, PeteC RE: Gutter Protection Systems Sure you could pay someone to come clean out your gutters, but I have to do mine 3-5 times a year. That would start to add up after a while. I was hoping to go with Leafguard, but apparently they aren't into my area yet. I had a quote from GutterTopper and it was over $18 a foot to ADD a cover to my existing gutters. I think not! I don't know what to do now. I thought about GutterFilter, but I have a lot of acorns and those won't just blow off like leaves. Sigh. Pal RE: Gutter Protection Systems Oh, I didn't realize you had to add gutters anyway, which of course has to be factored into your cost analysis and ultimate decision. I suppose everyone has to consider their own circumstances and compare the costs for cleaning vs gutter guards vs an entire gutter system. I have about 130 feet of gutter, some of it 3 stories up, so cleaning it myself was out of the question. I could pay someone slightly less than $100 per cleaning if I had to, but I opted for Alcoa's Leaf Releaf that cost around $500 (installed). Others have recommended even less expensive ones, but I liked the look of Alcoa's guard and there are some places where it can be seen from the windows. It has a classier look along with functionality, unlike cheaper plastic. But for me, to shell out big bucks for highly marked-up, franchised guards was out of the question. That's really the issue for me -- some products on the market are entirely too expensive (and with some, the gutters still have to be cleaned occasionally and removing the expensive guards is a burden -- thereby adding to the cost/frustration of cleaning when it has to be done). Had I paid $18 per foot, it would have cost a total of $2340! That would equal about 12 years of twice-yearly cleaning or 23 years of yearly cleaning (at the current rate). Obviously $500 for a guard system that's just as effective (in my opinion) was a better choice in my situation.
RE: Gutter Protection Systems Everyone, the only solution that prevents mosquitoes from breading in your gutters is GUTTERFILTER, and 60% or more of the mosquitoes in your neighborhoods are coming from gutters.... Mosquitoes are territorial an want to hang close to the water source, and you would too, if you doubled your weight, you would not be flying 20 blocks looking for a breeding area, it is right above your heads guys… RE: Gutter Protection Systems Crboone- it was good to read your post about LeafRelief by ALCOA. I called ALCOA to get a referral to a distributor here in Maryland. They gave me exactly 1 name and seemed reluctant to give me any others. Sure enough, I have left several messages for the company whose name they provided to no avail. No response. I'm calling ALCOA back tomorrow to get another name. At least I know it's worth the effort if you're happy with their product. RE: Gutter Protection Systems I also am looking to replace my present gutter covers which are aluminum inserts under the shingle and then resting on the lower lip of the gutter. We are heavily wooded with oak trees and numerous wildlife which dislodge the 3 ft sections of covers. Debris and plant life quickly accumulate. Gutter helmet has quoted $3400 for 236 ft plus two 3x4 downspouts. That works out to about 15/ft since the contracter gets his covers from the local franchise company and then undercuts them by not charging for the cleaning work. My feeling is that the gutter helmet will probably prevent less debris into the gutter but the cost is not acceptible. There does not appear to be any objective studies comparing covers. Anecdotal evidence will have to suffice. Does anyone else have any long term experience with the Waterfall? Is the area heavily wooded? RE: Gutter Protection Systems I would encourage anyone looking at gutter protection systems to look at Elko GuttaGards. This is the company that makes the reverse curve panels for Brookstone catalog, as well as Improvements. You can buy GuttaGard at Do-It Best centers, or at Brookstone or Improvements, or at www.guttersdirect.com. I looked at every system you can imagine, and this product works, requires no maintenance or cleaning, is simple to install, and is invisible from the curb . . . and it's not unappealing from upper windows. I'm a cheapskate . . . why spend $20/ft. if you get better performance for $1/ft.? GuttaGard has a small website at www.guttagard.com. RE: Gutter Protection Systems We installed Waterloov and in a way I'm sorry we did, because: If we build (hopefully), I don't think we'd use any kind of gutter guards again unless there were trees within 25 feet of the house. RE: Gutter Protection Systems We need to replace our roof in the next year or two and I wondered if these types of gutter systems should be installed at theat time? RE: Gutter Protection Systems I am considering the Alchoa Leaf Relief system but having a difficult time finding an installer. I am in Newton MA, any suggestions. RE: Gutter Protection Systems Also happy to save a buck when I can, I used a product that looks like Guttagard. It has more than paid for itself many times over, but it's not really as effective as I'd like. Part of the problem is that they rely on the existing gutters to be installed properly (versus the entire gutter being replaced, presumably correctly). I think mine are not sloped quite enough. They also leave a little gap at the end which is just big enough for sparrows to fly in/out of for nesting. My bain is tulip poplar seeds that I don't even know where they are coming from. The trees here are really tall and the seeds could be floating down from a few blocks away for all I know. Despite their shortcomings, I repeat however, that they are more than worth their price. Spending thousands on my gutters isn't exactly a priority on my needy home. RE: Gutter Protection Systems Just a follow-up re: LeafRelief by ALCOA. I called ALCOA back after the first referral that they gave me to an area contractor didn't pan out (no returned calls). I'm in Maryland. They gave me 2 more names. This time I hit pay dirt. Both referrals provided prompt estimates. One charged $11/linear ft. and the other charged $8/linear ft. The difference, I'm guessing, is a bonus for the salesman/estimator who offered to discount the price by 5% without hesitation. RE: Gutter Protection Systems Has anyone installed Gutterbrush on their homes? any real feedback out there ? RE: Gutter Protection Systems cander328, Hope this helps. RE: Gutter Protection Systems I heard of a product called "gutter pump" on the radio. I pulled this off an advertisement on the web: Anyone heard of this? I'm a little skeptical based on what I've seen thus far. RE: Gutter Protection Systems I'm surprised to see the $8 and $11 per foot estimates for Alcoa's Leaf Relief. I believe I paid $4.50-5 per foot several months ago, but maybe that has to do with location. But my impression was that the Leaf Relief just did not cost that much. Nesting birds are not a problem in my case. With the gutters & guards installed properly, there is no gap anywhere for them to get in. And, Leaf Relief is not a screen system -- it has small holes or perforations that prevent anything of any size from getting through. There is some debris accumulation on the guards (mine have been installed for several months now), but so far not enough to block any sections. I'm still monitoring that. An added bonus of the Leaf Relief, if this is important to you, is that the guard strengthens the gutters. Gutters typically have brackets or hangers at intervals to reinforce the gutter. With the Leaf Relief, you have a continual reinforcement from end to end because of the way the aluminum guard fits just inside the gutter opening. Unfortunately, I can't really use anything like a gutterbrush or cleaning attachment conveniently because my gutters are just too high up. RE: Gutter Protection Systems after working through this thread, we had leaf relief installed on our 3 story steeply pitched roof which is surrounded on 3 sides by trees. so far so good. thank-you. thank-you. thank-you. it works and you saved me a ton of time. to Cander: Alcoa gave me 2 contacts that didn't pan out. I just kept calling all of the (what seems like a thousand) gutter guard companies in our area until I found one that installed leaf relief. RE: Gutter Protection Systems I found the comments on this thread to be extremely helpful in selecting a leaf guard system. We are currently replacing our gutters and installing a leaf guard system. We are on a heavily wooded lot. The current gutter system was poorly installed, without a drip guard, hence the need to replace a system on a 9 year old house. RE: Gutter Protection Systems Does anyone know how the Leaf Relief system works in winter for melting snow? Do the holes in the cover ice up preventing water to flow into the gutters? Also, I am interested in knowing now that fall is in full swing, is anyone having issues with the perforated cover clogging due to leaves or debris laying on top? RE: Gutter Protection Systems Lorl3915, Q.) Does Leaf Relief cause ice damming on my roof in the winter? A.) No- In fact, Leaf Relief provides you with several winter weather advantages over open gutters and competitive leaf removal systems: 1. Less weight build-up in gutters. 2. Faster de-icing and resumed flow when the temperatures raise above freezing. 3. For most slopes, ice and snow slide over Leaf Relief and off roofs easier than open gutters. 4. Unlike many competitive products, the installation of Leaf Relief does not interfere with the roofing materials and therefore no opportunity for water, snow or ice to cause damage by leaking through your ceilings exists. RE: Gutter Protection Systems Hi! We too are looking at options. I've gotten an estimate from "The Gutter Guys" for their version, which is called Guttergard. This is one that slips under the shingles and is attached to the gutter with screws. Of course, they claim it is great, but it seems any of these things - Waterloov (which is probably the closest to Guttergard), Gutter Helmet, etc. have their pros and cons. I'm really concerned about water spilling over the gutters, because that will cause a wet basement problem for us (past experience talking). They say it is "engineered" to handle up to 22 inches of rain per hour, but of course I'm sure those tests don't include a bunch of leaves coming down as well. Does anyone have any experience with The Gutter Guys or their product, Guttergard? We do live in a wooded area, and maintenance/cleaning of our gutters is a real problem!!! It is very difficult to reach them, and they clog something awful. Thanks for the help! Here is a link that might be useful: The Gutter Guys - Guttergard ---------------------------------------------------------------------- ---------- RE: Gutter Protection Systems As promised, an update on the LeafRelief system. It was installed last weekend. Still a few leafs hanging and dropping. Shortly after the gutters and LeafRelief was installed, we had a heavy rain (i.e. one inch within 8 hours). I see wet leaves sticking to the top of the LeafRelief. Somewhat concerned, however not enough to block the gutter at this point. I am waiting for the some dry days to see if Alcoa claim that a 2-3 mph wind will clean the top of the LeafRelief. So far, two days after the heavy rain, and still leaves are collecting on top of the gutters. RE: Gutter Protection Systems I have been reading through this thread and this is probably the most helpful thread I have been through ever, in particular because of CRboone and John Allen especially. I have been looking for gutter guards and live in the Raleigh, NC area. I live in a similar setting as CRBoone, with 3 stories and house surrounded by trees and pine trees. I emailed Alcoa and they sent me three contractors. One came and gave an estimate but was high, 10.50 - 14.50 a foot. He also said they call theirs something else, they have a lifetime warranty, and they do install under the shingles...the other two said they only do siding not gutters. Does anyone else live in this are that is familar with a contractor? Crboone, I see you live in NC, do you live near this area where you can supply your contractor's name to me? Is anyone familiar with the contractor that I got the quote from called Patton General Contracting? They appear to be in NC and SC. They called their product leafproof but said it is the leafrelief product, which I thought was strange. RE: Gutter Protection Systems Has anyone had experience with a product called Sheerflow Gutter Filter? It seems to have some of the advantages of the Leaf Relief product, but also may have overcome some of the Leaf Relief disadvantages. Since it is installed under the roof shingles (but not nailed or screwed to the roof), it is at a slant and doesn't lay flat like Leaf Relief. It has a screen under the holes, Leaf Reilef has no screen. Also it looks like it may be easier to get off than Leaf Relief if the gutter does need cleaning. I am going to get samples of both and test them, but was wondering if anyone knew of the Sheerflow. Here's a picture of the Sheerflow product. Here is a link that might be useful: Sheerflow Gutter Filter ---------------------------------------------------------------------- ---------- RE: Gutter Protection Systems Does anyone have experience with the KGuard gutter system. I have a roofer in Dayton, Oh, who wants to install it on my home. We have lots of big trees, but a unique situation in which we need to keep water away from windows that come up directly off the flat roof to a second roof. It has been suggested that we use this on both the lower and upper roof, and I am worried about runoff during heavy rain. The roof has a bit of a slope. I also am worried about ice damns in winter. Any experience with this system? thanks so much. RE: Gutter Protection Systems Oliverthelonious, Thanks, John Allen RE: Gutter Protection Systems I am a general contractor that has install both products: Gutter Filter and a simular product called Gutter Stuff. I haven't seen it mentioned yet. It seems to be better due to its stiffness compared to the filter and the product is much more pourous than Gutter Filter. I have installed both and needed to replace Gutter Filter product with Gutter Stuff due to overflow issues with Gutter Filter. I am curious as to what people have heard about either of these two products. The filter products work extremely well with needles and small debris problems. RE: Gutter Protection Systems penglish - I live near the Raleigh area and am actually having the Leaf Relief product installed on my house today. The first time I heard of Leaf Relief was when a company called Baker Roofing came out and gave me an estimate for it. They wanted to charge me over $1300 and insisted that I needed new gutters in several places and also to put a gutter along one side of my house that currently doesn't have a gutter at all. They said that spot needed a gutter to protect my AC unit, but ironically, I checked with the heating and air guy that was out the next day and he said that there were no problems with how it is set up now. He said that the AC unit is set up to handle water and that the roofing guy was just trying to get more money out of me that I didn't need to pay. I then called Baker Roofing back for an adjusted estimate and it was still $1000. Once I started researching the product I came across this forum posting and found all of the great information here extremely helpful. I contacted Alcoa and they gave me 2 names of contracters in my area that installed their Leaf Relief product. I called them both (one was Patton General Contracting). I had the exact same experience that you did! They showed up and had an entirely different product that what I was expecting (their LeafProof system) and tried to convince me that it was the best system. The guy that came out said he was a manager or something and implied that we could only get the *good* deal he was offering if we agreed to purchase that very same day. Their price was almost $1000. I didn't call him back at all. The next week the other contractor that I had called gave me an estimate for the Leaf Relief product and it was only $510!! The contractor is Gerald Jones Company. Here's the guy that I've dealt with: Gutter Protection Systems fpr New Home Thanks to everyone for such great information. I am in the process having a custom home built. The lot is wooded on three sides and with basement wil be three stories high. Based on reading this thread, I think I should tell my builder either: RE: Gutter Protection Systems for New Home Sannah, If your planning on having Leaf Relief installed, your gutter installation company should be able to install Leaf Relief at the same time your gutters are being installed. Leaf Relief is made to fit 5" or 6" gutters. If you have any questions feel free to email me. John Allen RE: Gutter Protection Systems My contractor installed gutter guards on our 7-month old home last week(should have been done sooner, but that's another story). He never communicated to us when it was going to be done, so we got an estimate from another company. This second company said our gutters are not sloping in the right direction. When we contacted our contractor, he left a message on our answering machine, saying he installed the gutters with the slope of the house. The answering machine cut him off as he was trying to justify his work; he never bothered to call back and has not returned our calls. RE: Gutter Protection Systems Just wanted to follow up with the folks that went with the Alcoa LeafRelief. Are the leaves and pine needles collecting on top of the gutters? I'm concerned that here in CT with snow/ice and what not in the winter that the gutters will freeze. RE: Gutter Protection Systems Cheerful, If it were my house I would have to tell the original contractor that he has an "x" amount of time to make the necessary repairs or I would contact the BBB if he does not cooperate to file a complaint. You could pay the other company to make the repairs but you may not recover your money from the original contractor, so I would make every effort to get the original contractor to make the repairs. Hope this helps. RE: Gutter Protection Systems I have been watching this site for quite some time, and no one has discussed the gutter cap, we had it installed about a year ago and enjoy watching during a rain storm, it works just like they said. we also bought the heater cap and it is unbeliveable, all my neighbors get up to 6 foot iceicles and we get none, and our gutters stay free flowing. one of our friends has a competitors product and he has the biggest ice problem in the area. hope that helps someone. |
| The worst mistake I ever made was getting LeafGuard gutters. The trash from the trees just sits on top of them and they cause ice dams. Being a one piece system with a solid 'lid' the air flows through the gutter freezing anything that lands on it... Unfortunately the shingles above them get warm and melt the snow and you end up with five foot icicles hanging off your gutters. If you feel you must get some sort of gutter system talk to at least 3 people in YOUR area who have them. Rita |
| Hi Rita, Just curious, is Leaf Guard doing anything to rectify your problem. I know if you were my customer I would be doing whatever I could to make it right. Just wondering if Leaf Guard is making any attempts to correct your problems? Thanks |
| Personally, I don't think there IS anything they can do about it. It is an innate defect of the product. I wonder if they ever tested them in a cold climate. There is not a gutter guard in the market that effectively works. I went to home improvement store and purchased an attachement for your hose that water blasts junk out of the gutters without having to get on a ladder. It only takes a few minutes every few months to keep the gutters clean and functional. Best part was it was free with rebate! And it works 100% better than any gutter attachment I have tried.
| Cingrp, unfortunately halds is right, there is nothing they can do... That's why they only guarantee that they will never clog... It's hard for anything to clog when nothing goes in them... As for customer service... Well, I have been trying to get then back out here all year to do something about one of the corners, the seam is loose and it leaks.... They went through all the regular excuses, it was too cold out, it was too hot out, they were short of help that day and on and on... Then they came up with a few original ones.... The repair guy and to go to a funeral, his wife's, uncle's, steps son's cousin passed away and the funeral was in Las Vegas... The best one was..... While I was sitting here with five foot icicles, he couldn't make it out for another two weeks because he sold so many systems he got a free cruise! Here's a pic to give you an idea what I put up with last winter... I was leaning out the upstairs window, the gray area on the left is the underneath of the gutter...
So now when anyone speaks of gutters I tell them of the terrible time I've had with LeafGuard gutters.... And.... Every time it snows I put out their sign with a big red and yellow arrow pointing to the icicles. Rita |
- Posted by Dave_Farnham (leafreliefstl@aol.com) on Mon, Oct 3, 05 at 23:42
| Amlar, Leaf Relief is a product by ALCOA. It does come with a 10 year warranty not only on the product itself but guaranteed not to clog or overflow. As a company they do stand behind the warranty. That should pay off any investment each year for several gutter cleanings. RitaOtay, |
| Thank you Cingrp for posting that thread. I remember seeing that a long time ago but could not find it. Very helpful. I would love to have heard from some of those people in terms of the long term usage of Leaf Relief. It sounds great on paper but do the leaves and needles blow off of it or do I need to go up there to do so. My roof is too high for me to comfortably go on to so that is what I am trying to avoid. If Leaf Relief works then I can avoid getting up on the roof and after 4 and a half years be saving money over having the gutters cleaned. If it does not then I have thrown money away which I hate doing. Any more thoughts, I have to decide shortly. |
| Hi Amlar, I have Leaf Relief on my house and the main trees I have to deal with are pine trees and maples. I have one (pine tree) that sheds really bad in the front along with a maple tree that sheds the maple tree seeds (whirly birds). I also have two pines in the back of my house too. I live in an area where the condo association is suppose to keep the gutters clean and when I first moved in I had to clean my gutters out every month. After numerous calls to our association and poor response in getting them to come out and clean our gutters (because our basement kept flooding out), I decided to have Leaf Relief installed. I've had the product on my home for about 2 years now and it's working great. My next door neighbor decided to have it put on too because she was having the same problem (a wet basement - due to clogged gutters), our units are attatched. Since we have had the product on, we haven't had anymore floods in our basement. I can also see the top of Leaf Relief from one of my windows. I can see where a few pine needles and maple seeds may sit from time to time but for the most part, all the debris seems to blow off and any small debris that has layed on top has not caused a problem with any clogs or overflows. Any way, that's my experience, hope this helps. |
| Cingrp: Since you have had the product installed for 2 years, can you comment on winter conditions? Do you get icicles, etc? |
| Hi Mary, When we have had very long periods of sub zero temperatures, I might get a few small icicles but for the most part I don't get any. And my neighbors that have the reverse curve systems, they have the long dangling icicles hanging from their gutters for most of the winter. I like the fact too that I don't get any of the heavy ice and snow build up inside my gutter which use to pull my gutters loose. |
| I've had Leaf Relief installed for about a year 3/4 and have had no problems. A little debris does collect in some areas, but it doesn't keep building up. Most of it blows off or whatever. So I haven't had to have the gutters cleaned like before. No problem with icicles yet either. |
| intruth; Yes I've been out many times during heavy rain falls; including the torrential rains we've had during the Katrina storm. No overflows here with my Leaf Relief system (for over two years now). My basement use to flood all the time when my gutter were clogged with pine needles and maple seeds. I haven't had a flood or any overflows since I've had my Alcoa Leaf Relief system. And quite frankly this system doesn't cost near what some of the other systems do, plus it's guaranteed not to clog. Email me and I'll give you my address. Your more than welcome to stop by during the next heavy rain. |
- Posted by brushworks (My Page) on Tue, Mar 28, 06 at 7:41
| Leaf Relief will not clog..however, there is no guarantee that your gutter will not clog. Small debris like needles, shingle granules, seed pods, etc. pass through the holes in Leak Relief. That debris then slows down the gutter flow and will build toward the spout end, clogging it in less than one year. cingrp, pull off a section and inspect the gutter tray. Take a picture and send it to us. Michael |
| Hi Michael; My digital camera has been acting up lately, but I will check the gutter and take a picture the first chance I get. If I can figure it out; I will post the results on here. You said: "Leaf Relief will not clog..however, there is no guarantee that your gutter will not clog. Small debris like needles, shingle granules, seed pods, etc. pass through the holes in Leaf Relief. That debris then slows down the gutter flow and will build toward the spout end, clogging it in less than one year. Just for your info. I've had Leaf Relief on my gutters for over two years now; under major shedding pine needles and no clog or overflows. If you go to the link below you will find that Alcoa does guarantee the gutter from clogging or overflowing for 10 years; and it is guaranteed against your gutter filling up with debris and blocking the downspout. Look at section #4 and you will see the guarantee. I read over all this warranty stuff before deciding to put the product on my gutters. Crboone has posted in the forum recently too; he had the same problem I had and he reports his system is still working good too. :) |
Here is a link that might be useful: Leaf Relief warranty
| I purchased Leaf Relief gutter guards in October of 2005 to be installed over my existing gutters by a contractor. They cost me $625 for 136 feet of gutter space. They performed really well during the fall. However, during the early spring of 2006, oak trees that surround my home covered them with blossoms. The guards continued to perform very well even during the heavy rains of April. There were no overflows or gutter blockage. I am yet pleased with the guards even though I was told that they would require little to no maintenance to keep them functioning properly. |
| Is anyone familiar with a product called GutterGard? It seems to vary from the Gutter Helmet type in that it has a series of surface-tension entry slots (two small ones, then the larger one). We got a quote, for about 40' of gutter and two 20' downspouts, of $930. I'm still trying to find a message describing how someone attached plastic Lowe's or HD solid covers (with surface-tension slot) to vinyl gutters using sheet-metal screws. I bought 5 of them (each 4' long)the other day, for $3.85 each, and have three of them just tucked under the shingles. Maybe I'll figure out how that other poster screwed them down. |
- Posted by Jason(imjrock@msn.com) onSat, Aug 19, 06 at 18:00
| Just wanted to clear some topics up on gutter guards. Any company selling a reverse curve product is near the end! The reverse curve patent was started over 100 years ago and that being said there our many better solutions out to keep your gutters cleaned. I read a post about a 1/4 way down that was making fun of a company for showing how easy a product is to install but in order to warranty it they wanted it installed by a authized dealer... that makes alot of sense. A product is as only as good as its installed, well that is mostly said on the new mesh products like www.leafsolution.com and leaffilter. If everything is installed correctly then leafsolution is te best thing on the market. It is a all aluminium base product with a stainless steel membrane that doesnt even allow single grit to get into your gutter. It keeps out bugs,birds and any tree fallin object. The system was installed on my home in the gutter with some brackets. I have 40 yr shingles and didnt want that to mess with the warranty of my roof so they used a siding break and made the product lay ontop the gutter. All i can say is i havnt cleaned or had to mess with my gutters in 2 yrs plus and its the best choice i ever made. it cost me aroind 8.50 afoot installed and it was worth every penny! |
| I'm glad to hear so many people have had good luck with their gutter systems... However. I still say the LeafGuard system is a total waste of money... For what I paid for the system I could have had someone come out twice a year and paid them $100. each time for the next 20 years... Not only do I have to put up with ice dams, icicles and avalanches of ice and snow coming down on me in the winter, I have piles of leaves on the tops of the gutters in the fall... In the winter I have to go out there, every time it snows, to sweep the snow off the gutters... In the spring I have to sweep the debris from the trees off the gutters.... In the summer I have to actually go out there, at least twice, and wash the gutters because of all the gunk that sticks to them and sweep the leaves off in the fall.... Any my latest gripe, have wasps nesting in my gutter system. Something else to think about... Regular gutters collect leaves and debris but with a capped gutter system the mess has to go somewhere, it usually ends up on the porch, bushes and flowers... To my way of thinking we'd be better much off with wider, regular, gutters. Rita |
| Ritaotay, Have you considered having the Leaf Guard gutters replaced by another brand, such as Leaf Relief? |
- Posted by toastguy(xinyiguy@yahoo.com) onTue, Sep 12, 06 at 18:08
| I've ordered the Gutterbrush test kit, $39.99 for 12 feet, and the Sheerflow Gutter Filter 13.95 for 15 feet, from Brookstone.com I will be testing these out this year, and see which one works better before deciding to do the whole house. I have lots of pine needles mostly, so I will see how these products handle that. My roof is too steep for me to be going up there every year. I'd liket o hear anyone elses experience with either of these products.
- Posted by toastguy(xinyiguy@yahoo.com) onThu, Sep 14, 06 at 2:01
| Someone earlier in the thread asked about the Gutter Pump. I bought a few at Home Depot for a couple of bucks. I am not sure that they work that well. What I find works just as well, is the plastic mesh,
| I'm doing some tests of the various gutter products, before doing my whole house. I'v bought some solid vinyly gutter covers, So far they look to work o.k. I'll see how it functions over the next year. There is also some plastic GutterWorld guards witha a nylon filter. These are $1.98 for a 3 foot lenth at Home Depot. Anywyas, I am testing 4 products now : Gutterbrush These are all pretty cheap solutions, |
- Posted by sierraeast (My Page) on Fri, Apr 4, 08 at 20:38
- Posted by Keith McKinley(keithmckinley@yahoo.com) onMon, Jun 23, 08 at 10:35
| Just ripped it out. I did a small (20') test gutter for over a year. While it eventually sheds most leaves, key word being eventually, it DOES NOT shed needles, tree flower buds, whirly gigs, or that stringy crap that comes from oaks in the spring. This product is NOT WORTH THE MONEY |
| I've had Leaf Relief for a year and a half. So far, so good. I have mostly oak leaves. They land on top of the screen and blow away when it's windy. |
| I, like most of you have tried several gutter covers. My house has several large trees near it, some are the sweet gum trees that have these prickly balls about 1" in diameter. They will clog your downspout or gutter quickly, it only takes 2 or 3 of them to completely stop the water flow. I have tried some of the reverse flow models but maple tree "helicopters" pretty much eliminated them and I would have had to lower my gutters to make them work properly. I have also tried wire mesh etc. and all have some drawbacks. I installed Leaf-Relief guards on my house myself. They are relatively easy to install. They are very well made, come in 10' lengths instead 3'or 4' and I think they will be the best thing I have tried so far. The lip on the front seems to be a trap for debris but if you watch the cover work, the lip acts as a guide to prevent the water from going over the gutter during a heavy rain. My only issue so far is that my 2-story house has a lower roof over my garage. The builder ran downspouts from the upper roof to the lower roof and the upper roof drains directly onto the lower roof. During a heavy rain the water runs over the top of the Leaf-Relief guards. They can't absorb that much water quickly enough. I e-mailed alcoa and they said that the upper gutters should drain directly into the lower gutters not onto the roof. This is really not that big of an issue, there has to be a substantial rain to overflow this and it is only in an area of about 1 foot. Considering the cost ($3 ft.), I think this will work as well as anything else. There is going to be some maintenance with any of the gutter covers and these will probably be a minimum of effort to maintain. They do still work even if there are leaves on them and they stay relatively clean on their own but will certainly need to be brushed off occasionally, that's better than what I've been dealing with for the last 15 years or so. I hope this helps some of you, I have been dealing with this for a long time, it has gotten so bad for me that I lately have had to clean the gutters everytime rain was predicted in my area. Mike |
| Thank you Mike912. We have the same two roof design. The Leaf Relief would not work for us. |
| It's 2 1/2 years now with leaf relief and I am pleased. I also have a two roof design that discharges to the gutter over the garage and haven't seen a problem with overflow. It would not be hard to extend the downspout from the upper roof down into the lower gutter to eliminate that problem. I wouldn't eliminate leaf relief just becauses of a two roof design. |
| Found this thread looking for a appropriate leaf guard for my own home. Love to have those threes around but they shed pretty much leaves and I hate climbing up, not comfortable up there. I have seen a different design leaf guard I wonder if you guys have experience using it if so I would appreciate your feedback, check it out here; Easy Flow |
| If it has holes they WILL become clogged by debris. |
- Posted by John Sutton(Jsutton@verizon.net) onTue, May 17, 11 at 15:32
| I purchased Rhino Diy at Costco's over the weekend and installed them yesterday. You can just look at it and tell that it works. It has a smooth mesh that won't even let sand in. The install was a little time consuming, but it did not bother me. I feel pretty good that my gutter cleaning days are finally done! Thank you |
