Tue, Aug 12, 08 at 23:21
| I replaced the large gear in the worm gear kit .But it still does not work every time i press any of the remotes all i hear is a relay clicking on and off.The light does not work either.Is there a reset? or is there somthing else wrong.also the green light flashes 5 times. |
- Posted by don_1_2006 (My Page) on Wed, Aug 13, 08 at 17:50
| When it doesn't work is the door in the up position? If so the trolley may be jamming against the bolt just in front of the motor unit. Adjust the up limit found on the side of the motor unit 2 or 3 turns in the opposite direction of the arrow printed on the cover. |
- Posted by vito_dragon (My Page) on Wed, Aug 13, 08 at 19:41
| it does not matter i even tried it with the chain off and it still does not work .i bypassed the switch and then it works the moter works and every turns with the chain off. |
