someone help me with attic fan?
Posted by kimberly82 (My Page) on
Wed, Aug 4, 10 at 15:37
Can someone help me on attic fans?
I know this is heat and air forum, but i didnt find a place for attic fans.
Okay my mom calls me at work, loud screeching coming from attic. the neighbor came out because she also heard it.
So i go home to check and it stops before i get there,
i call my dad and he said it might be attic fan so he comes over and disconnects it but at that time the fan is running and no noise, maybe it had noise trying to start? but its not making it now.
So does anyone think this noise is coming from that? is it a belt? or bearing?
okay i just brought the house- I have home warranty-they cover attic fans, but not belts. so do you think its the belt or is the fan going? because i dont want to spend $100 for home warranty contractor to come out and tell me the belt is not covered. and lose $100 where i can get someone to replace it myself.
Any thoughts to what it is?
any help is appreciated. first time homeowner.
Kim
RE: someone help me with attic fan?
Tough call. I'd send someone up with some belt dressing (automotive store) to check the tension on the belt and inspect for fur, feathers or other debris that may have gotten caught between the blades and the shroud and see if it happens again.
There is absolutely no way anyone can actually diagnose this problem over the internet.
You need to find a competent handyman or HVAC repairman and have them actually test the fan and look at the belt(s).
It could be literally one of a dozen possible problems. Loose belt, case hardened belt surface, deteriorated belt, dry bearings(there may be three), trash blown in and causing belt slippage, motor problem, fan blade problem, shutter problem(if installed), voltage problem, or a critter stuck when the fan started.
