Water getting filled up in backyard
Posted by pmysore1 (My Page) on
Tue, Aug 21, 12 at 11:34
Hi All,
I am trying to evaluate whether below situation is really an issue.
Please let me know your suggestions.
1) In our backyard we recently built a flagstone patio on a concrete base.
2) Patio length is 25 ft from the back walls.
3) We had two water sprouts that got buried below the stone patio and draining water out well beyond the patio perimeters
4) Patio is built on pretty good gradient level (Our backyard has a good slope). Patio has a seating wall on the far end of the patio.
5) There is small water pipe (half inch) through the seating wall to drain out water from the patio surface
5) We are in the process of making flower beds just on the perimeter on the far end the patio just behind the seating wall.
6) As we were digging, after about 1 1/2 feet, I saw water oozing out and filling half feet up the hole. Day before digging we had heavy rains in the area and soil is very clay.
7) I emptied the water from the hole and went back to see it. Again I saw half feet of water. I emptied the water again.
8) I repeated this 5 or 6 times and probably have emptied about 10 gallons of water.
10) Right above the place where I dug, the patio water gets drained out via a half inch pipe.
11) I dug another hole 4 feet away from first hole and I did not see any water. Second hole is slight on a upper slope.
Should I be concerned with this water getting filled up in the whole?
Will it cause any future drainage issues?
Any possible damage to the patio?
Is it a good idea to put plants in that area?
Thanks
-Pradeep
RE: Water getting filled up in backyard
What is a water sprout? Do you have a septic system in the yard?
You could have a leak in a water line, a high water table or it could just be an area that doesn't drain well. How much rain did you have the day before?
I would leave the hole open for a few days and see if the water continues to collect. If it starts drying up, then I would suggest using plants in that area that like wet feet.
If it continues to collect water you need to identify where it's coming from. A water line, or sprinkler line, may have been damaged during the patio build.
