HELP!!!! Toilet rocking and leaking around base.
Posted by vldm (My Page) on
Thu, Aug 6, 09 at 10:44
My husband has tried to fix our toilet several times. We even had someone else to come in to fix it. It would be fine for a couple of hours then the rocking would start again. Then the leaking would begin. I am tired of cleaning up urine and my bathroom smelling like a sewer. This all started when the old flange broke. The person we called the last time cleaned around the drain pipe (which is in concrete) to ensure the flange was flush against the floor. The toilet was fine for a while then started to rock from back to front a little. Then eventually from side to side. I am guessing by then the wax ring broke. My husband is ready to go by a whole new toilet to see if that will work. Please help!!!!!!!
RE: HELP!!!! Toilet rocking and leaking around base.
Is the old flange still broken?
Did the toilet work fine until the flange broke?
Are the mounting screws properly contained in the flange?
Is the floor level(even) where the toilet sits?
If the flange is still broken, it must be replaced. Replacing the flange will take care of the mounting bolt problem.
If the floor is unlevel(uneven), there are shims(I recommend the plastic ones) sold at home improvement/hardware/plumbing stores to install to stop the unlevelness.
The only other thingt of which I can think is that the old wax ring/funnel assembly was not removed, causing the tiolet base to sit too high on the new(succeeding) wax rings and cause the rocking.
There is an alternative to the wax ring you might want to try as well. A friend of mine that manages apartments told me they work great. See the LINK below:
Here is a link that might be useful: Wax Free Gasket
Mac is right -- the flange must be replaced and the floor flat. Shim the toilet so it doesn't rock if necessary.
I've used the "wax free" devices that Drywall Guy suggested. They do work but the basics need to be right as well.
One word "plumber"
I ment to add if all else fails
