| It’s time for us to remodel our 1922 bathroom. The walls are lath and plaster, which is in relatively good condition except for a few hairline cracks. Over the plaster is a layer of "Keenes Cement" which is scored to look like subway tiles and is not in good shape.
We would like to smooth over the wall and remove the subway tile markings plus correct other chips and gouges in this wall. Also we need to repair the cracks in the walls. How is the best way to fix the wall? We were thinking about taping the cracks and skim coating the wall with a lot of layers of joint compound and sanding it to a smooth finish. Thanks |
| Durabond. Pre-mixed drywall mud will just make a mess of the surface. Durabond is not water soluble once set up, and as hard as the Keenes that is there. It will NOT sand, so do a smooth job. |
- Posted by shannon185 (My Page) on Tue, Sep 2, 08 at 22:58
| Thanks brickeyee for this information. I've found out from doing some kitchen repair with Keenes Cement that we do not have the touch to do a good smooth job. Is there any other material like Durabond we can use that can be sanded? What about Easysand 210? Thanks |
| You can use Easysand, but it often requires extra coats of primer and paint, especially if sanded heavily. |
| Use a 50/50 mix of plaster of paris and joint compound. We've been slowly doing rooms in our 1890's house, and the results with this mix have been excellent. Did the first room 12 years ago and it still looks terrific. |
| You might try regular topping over the easy sand to achieve a harder finish surface. So far the advice is well taken, there is a learning curve and the sooner you learn, the less you will need to sand. |
| "You might try regular topping over the easy sand to achieve a harder finish surface." Easysand is softer than Durabond, but any pre-mix is even softer. The plaster finish is usually a mixture of gaging plaster and lime putty. |
- Posted by newenglandbuilder (My Page) on Wed, Sep 10, 08 at 22:34
| Veneer plaster is made for skim coating. Mix it with 90 minute compound mix -- 3 parts compound to 1 part plaster. Don't use plaster of paris as it will harden up so fast you'll end up throwing most of it away before you get it on the wall. You can try the above suggested mix and/or work with the veneer plaster mix alone or experiment. Use a large, wide trowel to smooth it on and make up your own "darby" with a 2 x 4 about 2' long and attempt your final smoothing with that, wait and then sand and then fill your dips again until you get a reasonably decent surface. Try to work fast, working slowly and methodically will cause more errors and you will lose sight of the "big picture" and with this kind of work you want to focus on the whole wall -- the whole job and not just a line or a lump here or there. Also, irregularities that you can't get rid of can be feathered out and a fool the eye effect can be achieved by spreading the lump or problem over a larger surface so as to remove focus on one problem area. |
| The best way to repair the cracks in the plaster is to use a plaster adhesive. In order to repair the cracks permanently, you are going to have to ensure that the plaster is solidly attached to the lath behind it (if not, the crack just comes back). Using a plaster adhesive is pretty simple to do yourself. You drill down to the lath with a masonry bit all along the crack, spray the holes with a conditioner, and then fill with your adhesive. After that, you temporarily clamp the plaster to the lath with screws and washers. Wait 24 hours, remove the screws and you are done! Your plaster is structurally reattached to the lath. |
Here is a link that might be useful: Plaster Adhesive
