Tue, Aug 18, 09 at 8:09
| There is a strong musty odour emanating from the crawl space of our house, especially on humid days. The crawl space is about 3 feet high with a concrete floor. Ventilation is probably insufficient because the house is surrounded on two sides with a concrete verandah which makes cross ventillation impossible.
The area is relatively clean. I did notice black sooty spots on the white electrical wires... (Is there a way to include photos on this forum?) A heating contractor suggested spraying with a weak solution of bleach with a garden sprayer. Are there better short and long term solutions ? |
| The side that isn't blocked should be used to ventilate the space. Open two areas,as far apart as possible and install an exhaust fan set up to a humidistat. The other opening will be the intake as well as an additional vent into the living space. In the winter, close off the openings. Ron |
| Ron's solution would be the best. A short term solution might be getting a dehumidifier, as the dampness is causing the "sooty spot" & the reason to have the humidistat in the fan circuit. Use of bleach is a one-shot deal, very short term. |
