| Well i was in my attic getting a suitcase when i stepped on a hole of insulation. Now the ceiling under the spot that i stepped on has a small irregular crack on it. My ceiling is the spiky kind. My theory is that i broke the board that was holding the ceiling. How do i fix this?? the crack is like 7 or 8 inches. |
| "My theory is that i broke the board that was holding the ceiling." The "board that was holding the ceiling" is a joist, and is a 2x piece of lumber. What you likely cracked was the 1/2 inch thick drywall that IS the ceiling. Repairing the cracks usually involves cutting out the damaged area, putting a drywall patch in place, and then matching the texture. Matching is usually the sticking point, requiring knowledge of how the texture was applied. A good drywall person can usually figure it out by looking. Short uniform random spikes (not patterned) are often produced using a sponge roller in wet drywall compound, and it not hard to match. |
