Mon, Jul 5, 10 at 17:19
| I have wood rot on the outside of my doors towards the bottom. I have one of those composite decks and it holds water a little too well. Who would you call to repair this? I just have no idea where to start. |
| Call a carpenter or handyman who can replace the rotted wood and fix the deck. Decks should not hold water, and especially against the house. |
| Your best bet would be to use something like DryZone or DampStop. They're the most effective methods according to pros who buy from our store :) Other than that, try using a tanking slurry. |
Here is a link that might be useful: Tanking Slurry
| Are you saying that the wood alternative deck boards are holding water? I was thinking of using them to replace the few boards that are rotting on my lower deck. I have a web site for you to check out that was my bible when I redid my upstairs deck of my MB it is called bestdecksite.com it really was terrific when we redid our deck. Forget the HD how too books... The reason I referred you to that side is that if you support beams are getting weathered from the water that is seeping thru in between the boards this site had a great solution which was to cover the support boards with roofing felt so that the water can't get to them I thought it was a terrific Idea and will implement it when the lower deck eventually has to be totally redone. But for now I just want to do a few boards and am now concerned by your findings. |
