| Hello everybody.
As I mentioned in the plumbing forum…I’ve embarked on a project to remodel one of my bathrooms and at the same time fix some water damage. The water damage was caused by a leaky roof some 15+ years ago under some previous owner (I do not know the exact history). Now that I’ve opened up the walls and floor I would like to fix it. The effect of this water damage is visible as a wall and ceiling wallboard crack on the other side of the wall (in the kitchen). Apparently the water damage caused the floor to sag (by perhaps ¼" is my estimate) causing the cracks. The cracks have not been active in the past 10 years (no more movement) but, as you understand, now is the best time to fix all this. So the question now is how much to do and how, so I’d appreciate any advice. The following diagram shows the layout. Photos showing the actual situation follow. In the diagram you can see in BLUE where the pictures were taken. I’ve also marked in RED the work I’m leaning towards doing. Basically I plan to:
Joists are 2x8 on 12’ span, perhaps a little underframed by today’s standards, especially the two joists that carry the additional weight of the two joists that were cut to accommodate shower and toilet. And here are pictures: You can also access the pictures directly in higher res as http://i490.photobucket.com/albums/rr270/ThomasE_1/A1WaterDamage.jpg
Questions: A) Does the floor look damaged enough to warrant replacement? B) Does the joist underneath look sound? The wood looks stained but I poked it with a screwdriver and it still feels solid. This is one of the two joists that will get sistered anyway. C) As you can see in the last photo, the joist below where most of the damage is, also falls on a foundation gap. Is this a problem? (Seems to me that this may have aggravated things when it all got wet since that bottom sill was probably too weak to carry much weight when wet. I do have a solution in mind for that – I will post it perhaps later). |
| You have half the floor out already, why not remove the rest and put down 3/4 CDX that will be stronger once nailed and glued to the joists. Not only easier than piecemealing the floor together but stonger and less likely to squeak or shift. Everything else looks OK as long as it is solid |
| I will replace the floor. I will lay down ¾" CDX where I removed the planks and then lay another ½" CDX or plywood to tie everything together. However the issue is: What to do with that narrow portion of the floor that is under the damaged wall’s bottom sill ? I want to remove that too and also put a new bottom plate under that wall (as you can see in the photo, the original bottom plate is very fragmented – I guess they did that to bring the pipes through). |
| "...why not remove the rest and put down 3/4 CDX that will be stronger once nailed and glued to the joists." Only if you put it down on the diagonal like the original sub floor. I would never replace decent solid wood sub floor with plywood. |
| What I had in mind was to: A) temporarily shore up the wall by nailing a 2x8 to all the studs. Then, The reason I want to shore up things is that something gave way there when things got wet. Perhaps the subfloor lost some mass and/or got compressed, perhaps the bottom plate got deformed, perhaps the "gap" sagged, or perhaps a combination of all the above. I’m sure that something gave way because on the other side of the wall where the two walls meet there is a vertical crack all along the corner, from floor to ceiling, showing a displacement of about ¼". Perhaps I can fix the crack and things may never move again, but fixing things after I’m done remodeling the bathroom will be a PITA. |
| Arttofimpactwindows, thank you so much for the well thought out advice. I agree with you that there are complications to replace the bottom plate and floor underneath it. I already had some of the concerns you presented and you described some additional ones I had not quite thought about. So, now, there are perhaps a few extra factors to consider: A) I forgot to mention that the room on the other side of the wall (kitchen) will be remodeled soon and kitchen cabinets will be added, so I do not mind replacing the wallboard on that side too. As a matter of fact, I may just have to do that anyway to fix the ¼" vertical floor to ceiling wallboard crack on the other side. Now on the left side (see picture) where there is stucco, if any nails go from the stucco into the bottom plate, or bottom of studs, then I will indeed have to remove those. Perhaps I can add some angle brackets from the new header/bottom plate to the stucco to re-establish the same level of support. B) the kitchen side of the wall will have to be opened up anyway because the top plate of the wall does not pass the screwdriver test. At least a section of that top plate is soft as a cork. But I was planning to be fix that from the other side, when the kitchen is remodeled. C) My pictures do not show the complete foundation. So one cannot tell that the "gap" is only on the foundation wall, not the footing. The footing is contiguous and does not have any cracks. I think that perhaps implies that there was no foundation shifting (?) otherwise wouldn’t a ¼"-3/8" settling manifest itself as a crack somewhere along the concrete footing? D) Through a measurement (which I will not bother you describing) I estimated that about 500 lbs sit on the joist that falls over the gap. So, seems like the temporary 2x8, if preloaded with a floor jack (see notes on photo) should be able to take that load without deforming, right? That should also prevent the wall from re-settling onto the new members (as you described)? In any case, here is a pictorial description of my plan of action. If I decide to go ahead and do it, I will post pictures as the work moves along (will not start for a few more days as I am now into re-plumbing work). |
| PEX plumbing is done for now. So I removed the old galv pipes that were in the way and I’m now ready to proceed with the structural work… I installed the temporary header that will support the middle studs while I replace the bottom plate and install a permanent "header" low against the floor (as I had described above). I know the header in the photo (2x10 attached with ¼"x4" lag screws) looks like it was put there to support a dump truck, while the actual load is only about 600 lbs, but since I’ve never done this before I do not mind the overkill. Now ready for more demolition… |
| I would have used duplex head nails instead of screws, but it looks fine (if a lot of extra work). |
| Well this is last weekend’s work. I sistered the two joists running in the center of the bathroom floor and double sistered the joist that runs under the bathroom/kitchen wall. I double sistered this one because, seems to me, this interior wall also carries a bit of weight from the roof (eg some of the ceiling joists terminate on this wall). I am not sure if having this wall bear some load is ok, was intentional, or was poor building practice on behalf of the original builder. I shimmed where the joists rest on the sill to bring the floor closer to level. It is still not completely level in the center because the old joists have become a bit bowed. I reduced some of the bowing when I sistered the joists (pushed the center of the old joist up a bit with jack ~300 lbs before nailing the sister) but still not completely level. The slope is now 3/8" over 5 ft. I’m thinking that may be level enough. Not sure if it’s worth any extra effort to make the floor completely level (opinions welcome). As you can see in the photos, I addressed the subsidence of the joist that fell over the foundation gap by adding extra blocking and, of course, by hanging the joist from the 2x10 header using straps and a heavy duty joist hanger (rated at about 2500lbs). The joist hanger is not visible in the photos because it is behind the blocks. It does seem like overkill but I would like to think that I will not have any more problems with this area. Bathtub, insulation, vapor barriers and possibly tile will go over these walls and floor so they will be difficult to access in the future. I added a couple of extra studs where the exterior wall Ts into the bathroom wall (see comment on picture). Just in case the original studs had been weakened by the old roof leak. When installing the 4x10 low header, I also tried to cut the studs 1/8" longer to get a tight fit and shimmed under those studs that still did not seem to have a tight fit. Then I finally removed the temporary support header. Nothing seems to have moved, no new cracks. |
