| Hello,
I have to join two 10ft runs of aluminium k-profile gutter onto either side of a drop section:
The end product will look like in the lower-right corner of this picture:
Now, I have several options of doing the two joins:
I cannot go with seamless since one of the two 10ft segments "belongs" to me, while the other one is the neighbour's (who will have to replace her fascia in the coming years and tear the entire thing down again.) The 10ft runs are pitched 1/2". Because the joinery is extremely visible (man's height level and right at the entrance) I would prefer methods #3/#4 over #1/#2 because they have the minimal number of seams. However, I have yet to see an off-the-shelf part fitting the bill for #3 -- and #4 is barely mentioned anywhere. Is there anything obviously wrong with #4? Thanks!
- Posted by woodbutcher_ca (My Page) on Tue, Jul 27, 10 at 20:14
| Hi, Go with 4. I did mine that way and it was fast, easy and looked great.One fits on the inside and one fits on the out side, I allowed about two inches overlap.No cutting is needed to make the fit. On the outside one use some pliers and crush the channel on the top front of the gutter back about 2 inches. Put on some sealer on the inside of the outside gutter, start about a half inch from the end so you don't get any sealer on the outside. Install the inside gutter and fasten no need to crush the channel on the inside gutter.It takes me longer to type this than do the job. If you have old gutters practice on them. Good Luck Woodbutcher |
| I'd go with option 5. Have the neighbor replace her facia now and go with seamless. I get the feeling that is not a deck over a properly pitched roof and some sort of seat of the pants figure it out as you go assembly. If neighbor's facia and deck are rotting you are probably getting water in the common wall. Are mold and moisture problems common with these garages? How's your ceiling or was that already replaced? How's the neighbors ceiling? Any pictures of your actual condition? |
