Metal roof install botched
Posted by busboy (My Page) on
Fri, Jun 29, 12 at 15:18
A friend has just had her metal roof replaced due to hail damage. ($34,000) The roof is installed on sheathing. The installation has left dimples everywhere screws were installed. I contend that the screws should have been installed with a drill that would limit the torque to prevent this. Am I correct?
RE: Metal roof install botched
pictures would be the way for us to tell for certain, but you may be on the correct path.
Depth setting is more effective than torque setting.
we always put lathes and foam sheathing between lathes.
then screw metal to lathes.
Seeing that I have never seen a metal roof with dimples around the screws, this is clearly botched or an unconventional install.
I'd be expecting leaks around the seal of each screw in a relatively short time if I owned that roof.
Yes she is sick about it. I have advised her to contact her insurance adjuster. I would bet that they will probably have to sue the installer, probably to no avail, then cover the cost of another new roof. Thanks for the input folks. BTW I have not seen the roof, just some pictures.
There are probably manuals available online from the manufacturer for installation of the roofing panels. If not, for similar roofing panels. I bet they don't instruct you to torque the screws until the panel buckles. I think a suit would be a slam-dunk. The only question is does the installer have the $ to pay.
