| I am in the process of enlarging a space in the bathroom wall for a new medicine cabinet. A 3"x3" piece of plaster came off in the process. Is there any way I can secure it(maybe by seating it in some mud) in the affected area or must I start from the lath, which is intact, and build out with mud only? Thanks |
| You can try to use plaster washers to re-attach the piece, but it is likely to break and be a real PITA to finish out so nothing shows (a whole lot of feathering will be required). Some drywall can be attached to serve as a base, then use setting type joint compound mixed about as thick as peanut butter to bring the area flush. Setting compound will not shrink anything like pre-mixed mud if you use just enough water to max it workable. Easysand is not hard to work with, and can be sanded.
- Posted by chipster_2007 (My Page) on Thu, Jun 16, 11 at 20:34
| Thanks for your reply but could I embed this piece of plaster in some easysand on the wall, let it dry and then continue to fill in any cracks or spaces as well as smooth over the plaster with easysand? Will the easysand adhere to the plaster? If so, do I have to wet it first? Thanks |
| "could I embed this piece of plaster in some easysand on the wall," Easysand will not stick to the lathe well and form keys without adding fiber. |
