Sat, Jun 23, 12 at 9:48
| I need to buy a large quantity of triangular hook & loop sanding sheets for a paint scrape and sand project on my porch. I have been using the 60 grit sheets sold in stores, but Fein sells a 40 grit. Is 40 grit too rough to use on wood? Is there a reason Dremel does not sell 40 grit sheets for the Multi-Max, which I am using? |
- Posted by sombreuil_mongrel (My Page) on Sat, Jun 23, 12 at 16:57
| I used a Multimaster last fall to strip down 4 very large shutters (10' tall), so this brings back memories, and not good ones! I think I used 60 grit which came in boxes of 50 sheets, but still needed a finer sanding (80-100 grit) to be ready for primer. The oscillating action is not a smoothing orbit; it gets a lot done for the very small size of the pad. I know the Fein was designed for continuous use, I don't know if the same can be said for the much less costly Dremel version. I was sanding those louvers for days on end. Casey |
| Thanks. I will get the 60 grit. |
| Look at Kilngspore or one of the other online vendors for sandpaper. You do not need better quality paper for paint removal, it is going to clog very quickly. Using a paint stripper is much faster. |
| Thanks for the info, Brickeyee. This is for the soffit of a porch overhang. I am heating and scraping most all of the porch, but would rather just sand this area. |
