| Hello, we recently purchased a home just north of Atlanta that is about 15 years old. The home had the foam around the foundation which the previous owner removed because of the possible termite issues. I noticed today that due to the removal of the foam, I can put my fingers up underneath the siding pretty far in some places. I think this might be a reason why we have so many bugs in the house. I was planning on using expanding foam and then topping it off with caulking to waterproof it a little. But I was wondering, is it better to just stop at the foam? Does the house need the foam behind the siding to "breath" or get rid of moisture? Or any other suggestions on what I should do with this gap? Thanks for your help! |
| What kind of siding? What else is under the siding? Siding is not waterproof by itself, but there should be another layer of something (possibly even tar paper) that is the actual drainage plane behind the siding. If you seal the bottom of the siding any water that penetrates will not be able to drain. |
- Posted by energy_rater_la (My Page) on Wed, May 12, 10 at 22:21
| Like brickeye asked..whats behind the siding? is the siding vinyl? Houses don't need to 'breathe', most are not tight In our location (hot humid climate) houses dry to But foam next to the ground is a termite interstate. best of luck. |
- Posted by jamesmrosas (My Page) on Tue, May 18, 10 at 15:09
| I think that the house should not be too tight so that it will have a good ventilation. |
