Garage door opener
Posted by sandbob (My Page) on
Sun, May 11, 08 at 19:27
I have a Liftmaster garage door opener. The door will not close using the remote. I have to use keypad and hold button down to close. I did hose the garage, and sensors may have gotten wet. I had this problem before and paid $$ to have it fixed. I know there is a way to do it myself. The sensor with one wire has a steady green light. The sensor with two wires has a steady orange light. What color should they be, and how can I fix this. Thanks
RE: Garage door opener
i have 1/2hp Craftsman Garage Door Opener, i have 2 remotes, one key pad on wall and one pad on wall with three functions. my both remotes and wall pad were working fine so far. today i reset the pin pressing the red button and then putting new key on wall keypad, now my both remotes have stopped working. i can operate my garage through kep pad and wall pad using new pin but not sure what to do so that my both remotes are also working ...please help.
- Ram
Sounds like your logic board might be going on the fritz. If you think you might want to replace it yourself, I can tell you where NOT to buy it. I recently bought one from Ontario Supply in New York from their web site for $60. Unfortunately, it has turned out to be defective and they won't refund my purchase price even though I sent the defective unit back at my own cost. So, don't buy from them, they don't deal fairly in my opinion. I think you're best off just calling a local repair service and let them replace the board. If you replace the board yourself and it does not work, you're just going to end up calling a repair service anyway. Ontario Supply operates under the following web sites:
http://www.wholesalegaragedoorparts.com
and
http://www.liftmasterpartsonline.com/
In my opinion, you should avoid this company
