Fri, May 29, 09 at 15:37
| I have some cracks in the cedar siding after replacing some windows. The siding is 40 years old and in otherwise good condition. Can I caulk the cracks(none are wide)before staining the wood or must I replace the cedar siding or use vinyl siding over the cedar, which is much more expensive, to protect the wood long term? |
- Posted by danihilist (My Page) on Fri, May 29, 09 at 20:20
| Cost wise caulking with a paintable, good elastomeric is the least expensive of the choices. Not bad with small cracks. Just keep your eyes on them if they are in a lot of sun, especially if the cedar has a dark finish. |
- Posted by harpo_owner (My Page) on Wed, Jun 3, 09 at 11:02
| Thanks, I appreciate your reply. One of the painters in his bid wants to replace the cracked cedar siding with new cedar siding . I have read that that might be a problem due to difficulty in fitting new siding into old siding. Do you have any thoughts on This question Harpo |
