Unorthadox gutter protection idea
Posted by marlonius (My Page) on
Thu, May 27, 10 at 14:47
I have an unusual gutter situation with an attached carport and patio roof. I have a similarly unusual idea to deal with it but want to be told if I'm being crazy.
Both structures are corrugated aluminum, attached just below the roof of the house, with an adequate slope away from the house. At the far edge of the structure there is a gutter attached to the underside of the roof in such a way that it is impossible to clean out the debris by hand. A powerful leaf blower does only a so-so job.
Additionally, there is a downspout that drains directly onto my driveway and two downspouts that drain immediately adjacent to the patio and thus cause flooding of the patio. (I wish I could ask the builders what they were thinking)
So I'd like to run the downspouts into buried PVC pipe to prevent flooding and further water damage to my concrete, but I don't have a good way to prevent leaf debris from getting in using any of the commercially available gutter guards (they just won't fit into these irregular gutters).
My plan is to fill the gutters with pea gravel or crushed drain rock and find some way to cover the downspout openings to keep the gravel in. I don't think I could get landscape fabric or another silt barrier in there (I can't fit my hands into the gutters), but I guess I would have to attach a few cleanout holes to the downspout drains and use them frequently. The gutters are relatively small and appear to be actual structural members of the carport/patio cover so I don't think the weight would be an issue.
I feel like this has a decent chance of working but would like opinions because
a) when we eventually sell this house I don't want a home inspector to think I'm insane
b) since I can't even fit my hands in the gutters I won't be able to undo this.
c) I can't find any evidence online of this having been done before (although I can't imagine I'm actually the first person to think of this).
I'd appreciate any advice/opinions and alternative solutions.
Thanks
RE: Unorthadox gutter protection idea
Hard to picture the layout, but if it's between the house and one of the other structures you might consider whether that gutter is necessary.
Unless there is very little roof area contributing to the gutter volume and/or it rains very little, water running into the gutters will probably overflow.
You want your gutters to be as open and clear as possible.
Putting a gravel "filter" into them would not work as air borne soil (dust) and decomposing leaves, etc would soon clog them. Well, soon enough. Heavy rain would overflow them even if they weren't clogged.
I'd just use 4" PVC for the rain drains and have some wash out ports or cleanouts installed , as many as needed. 4" PVC will take anything a gutter down spout will put into it.
Given that it is sloped properly. 1/4 inch per foot is an aggressive slope for buried water drains.
Alternately, use a spun material, not unlike those 3M scrubbies pads, but on a larger scale, to cap the gutters in question. Cut strips of sufficient width and bend it into a U shape and pop into the gutter, legs down. The tension in the material will cause the legs to spring against the gutter sides. This leaves your guttering mostly open for water and the tops mostly closed off, certainly for leaves.
Material of this type is used in industry in a lot of applications. Various openess, densities, etc. for filtration of both air and liquids. The one I'm familiar with is used in primary water filtration banks in a tertiary filtration plant. Its grey, if that helps. ;)
I've seen it installed such that the up side is attached under the roofing material and then it comes down and into the gutter, an L shape instead of my U shape. I prefer the U as you can remove it easily and back flush.
Sorry, didn't mean for this to get so long.
There is a foam product called Gutter Stuff that uses this approach. (I've not used it, so no personal experience.)
I've seen the foam stuff or something similar, and think that might be the way to go, you'll still probably need to remove it and rinse it occasionally to remove the dirt but it's dense enough to keep leaves etc out. Seems clever to me.
Gravel would be much, much too heavy, but I like your thinking. Unfortunately, it'd rip the gutters and maybe the fascia off.
Landscape fabric will just clog. Can you fit the lightbulb-shaped screens made for the tops of downspouts in? Metaxa's suggestion sounds good.
I had an area with the similar problem of shingles overhanging the gutter & using the downspout screens with the cheap vinyl gutter toppers (the ones with diamond shaped holes and also a layer of netting to block the smallest debris) that just slide under the bottom shingles worked quite well.
Seems to me that rolling up any kind of medium scale netting or hardware cloth and placing it in the gutter would work to keep most leaves out--but might have to be pulled out periodically to clear of small debris like maple flowers.
Unfortunately my roofer talked me into installing permanent gutter guards--and the leaves & stuff just sit on top of them, so I still have to climb up to clear them. No better than what I described above after all that expense.
I've never had a problem with clogging of the pipes from the downspouts to the street--it's been over 14 years since installed.
