| I'm thinking about getting either a multi-tool (oscillating) or a Dremel-type tool (rotary). I'm wondering if there are advantages to either one--are there some things one can do that the other just can't?
I already have many standard power tools (reciprocating saw, jig saw, miter saw, circular saw, drill and impact driver, angle grinder, air compressor and nailers...). Things I thought I might use these types of tools for are:
If I can only buy just one, which one would you buy and why? |
| For some of the tasks you listed, drywall, sheet metal, hinge mortises, I'd probably default to hand tools. For the square hole in the floor, I've seen the oscillator do a much neater job that any rotary tool in a homeowner's arsenal. It is faster and can reach the cutting blade into the project without the motor getting in the way. Besides, it's a neat tool that I just gotta have! Replacement blade costs are the chief drawback that I've seen, though I don't how frequently I'd be faced with that. JMHO |
| This is also JMHO. Since I've never owned an oscillator, I'm not qualified to help with your choice. However if you do choose a rotary tool, I'd stay away from Dremel. I used mine for cutting holes in drywall, and the dust killed it. I borrowed my neighbor's for doing some fine cutting of wood, and killed that one. I think the motors overheat too easily. |
- Posted by sierraeast (My Page) on Mon, May 24, 10 at 13:14
| Dremel tools are typically for finer work/arts & crafts type projects where haevy duty use isn't required. Dremel now makes a multi tool. A multi tool should handle the projects you have listed just fine save the routing of the hinges. That's something that can be tasked by hand with a decent chisel and sharp razor knife with careful work/patience if you dont own a router. |
| Thanks for your feedback, everyone! |
| I have a Roto-zip ($150) and a Fein Multi-tool ($400 -but there are cheaper ones out there). This is what I've found from spending the last 7 years doing a complete gut and remodel (rebuild mostly) of a 130 year old farm house. For what you want. Fien tool - the rotozip struggled cutting through hardwood - lots of burning and went very slow - actually I don't think either it a great tool for this job- a good quality jigsaw would be better. - cutting sheet metal ducts and gutter downspouts - cutting notches out of tile for backsplash going around back of sink I found the rotozip worked wonderful for this (need the right bit) - put your tile on a piece of scrap sheetrock so you can keep the whole tile supported (just cut into the sheetrock). Was worth the full purchase price even if I never use it for anything else. - small routing jobs (hinge mortises) - cutting holes in drywall - detail sanding - cutting existing trim and baseboard shorter to install a cabinet BTW - I second what others have said - dremel is great for the hobbiest (woodworking, arts & crafts) but I've never considered it for construction type house work. I owned one years ago but gave it away at some point. Cathy |
| Are you talking about the new dremel Trio that's being demo'd at Home Depot? Anyway, they're both good for different things (so get both!) ----- - cutting a square hole out of hardwood floor for an air duct (although nails that aren't visible through the tongue & groove could make this tricky) drill, then jigsaw or sawzall (btw, those Ridid Fuego's look tempting) - the multi-blades would not hold up for this. --------- ----- - cutting notches out of tile for backsplash going around back of sink - dremel or dremel Trio ------ ------ - detail sanding ----- - cutting existing trim and baseboard shorter to install a cabinet |
| Wow, these are super helpful responses, everyone. Thank you so much! Homebound, I meant the standard dremel (not the dremel multi-tool or the new Trio). I'd be interested to hear any reviews of the new Trio, but I think I'm less likely to buy it than an oscillating multi-tool. Thanks again! |
