| Blade length - is it preferable to use the shortest blade necessary for the job when using a reciprocating saw?
I have a metal - maybe iron or steel, I don't know - piece of fence or gating that I need to cut up. A tree that I want to save has partially grown into it. I have to cut the fence into pieces in order to extract it. I'm looking at buying Tungsten Carbide Sawzall Blades. They come in 6 and 9 inch lengths. The 6 inch should be enough since the area is exposed - or is there some other factor involved. Or what about a Diamond Grit Torch Sawzall Blade? Would that make it easier for me? Here's what I am dealing with: |
Here is a link that might be useful: 6 inch diamond grit torch sawzall blade
- Posted by manhattan42 (My Page) on Fri, May 21, 10 at 18:29
| I would use a $5 metal cutting abrasive blade on a circular saw. It will cut faster. |
| Thanks, but I don't have a circular saw. I have the recip saw, an old jig saw and a dremel tool. |
- Posted by sombreuil_mongrel (My Page) on Fri, May 21, 10 at 19:23
| Hi, I'd use a metal cutting blade, bi-metallic, no longer than 6". Use a very slow speed on a variable speed sawzall. A short-stroke saw is best, like the classic milwaukee. At a slow speed it will cut like butter. At high speed you will burn up blades as fast as you can change them. Wrought iron work is made from mild steel. IOW very soft and malleable (for steel, anyway). Casey |
- Posted by mike_kaiser (My Page) on Sat, May 22, 10 at 6:46
| "Wrought" iron is actually mild (soft) steel and pretty easy to cut. Any old metal cutting blade will work just fine, although a bi-metal blade will last longer. Buy a couple. |
| The issue wot cutting metal is having enough blade teeth in contact with the material being cut to avoid breaking off the teeth. The lower limit is three teeth in contact with the metal being cut, so choose a high enough tooth count blade to achieve this. Slow speed and solid blade contact are also needed. A circular saw would not work well for this job. This job should not need a carbide grit blade. If you start with a file kerf a longer blade length is not nearly as important and can make the job easier.
| Not to be to retro, but this job wouldn't take long with a hacksaw and a good blade or two. You might want to have one at hand even if you use the recip. |
| Well, I wish you were nearby with your hacksaw and blade. My Sawzall and 6 inch Diamond Grit Castiron blade took forever to get through the first three pieces. I'm going to be at this all summer, I fear. |
| Grit blades are not known for speed. They are usually used only when the material is so hard a regular blade cannot cut at all, and at that point the grit works well. On softer materials grit blades are very slow since they spend a lot of time smearing the material back and forth before it breaks off. Soft but 'gummy' material can even rip the grit off the blade in short order (like a concrete diamond blade hitting rebar). Soft steel just needs the correct tooth count bi-metal blade. |
| You guys were right. The bi-metal blades worked much better and faster. Thanks! |
