Is it ok to smoke a hookah pipe through a 15mm copper plumbing pi
Posted by jemshkoj (My Page) on
Sat, May 19, 12 at 12:41
Have some asian friends who always smoke a hookah pipe on weekends.
I don't like using rubber hoses, so I have used a 15mm copper plumbing pipe instead. It fits perfectly in the hookah pipe outlet. At first everyone thought it was funny, but now used to it.
Its already eccentric to smoke hookah pipes in the UK, so I don't see it as odd to use my own tube. I guess it was funny because no one expected the copper pipe would be a perfect fit.
On other words, other noobs smoking in rubber, I am smoking metal.
Seriously apart from the health risks in smoking, such as tar. Is there anything less safe in smoking through copper, than rubber?
RE: Is it ok to smoke a hookah pipe through a 15mm copper plumbin
and you came here to ask that?
I can't think of rubber being safer. I'd stick with the copper, but maybe upgrade to stainless steel if concerned.
copper will work,,but only if you solder the copper pipe to your lips with lead free solder.....LOL
Having green tinted lips from the corrosion will be a distinctive fashion statement.
"Having green tinted lips from the corrosion will be a distinctive fashion statement."
If you absorb enough you will get copper poisoning.
Like everything, the dose makes the poison.
This may be the right forum if he gets too high & drops the pipe(I guess it would be lit wouldn't it? I don't smoke anything ever!!) Anyway he better keep this forum bookmarked when he needs to repair the place after he gets careless! Oh, might want to take a nail file & smooth end of pipe so you don't cut your lips!!
would that be the proper application for "pipe dope"
Wow, never expected to see a question like that here!
