Tue, May 18, 10 at 12:36
| I'm replacing some windows in a block wall with a brick exterior. The old windows will be completely removed and new windows installed. I was orginally planning on utilizing replacement windows without nailing fins, but wonder if there is a benefit to using a nailing fin. There is a wood buck on the block wall that has a rough opening small than the exterior brick opening. The exterior brick opening allows approx 1.5 inch on all sides. Should I utilize a window with nailing fins and then flash the nailing fin or should I flash the wood buck and use a replacement window without a nailing fin? |
| i'm sure we used the fins on our home. i did a quick search and found this..hope it will help. the directions are pretty "thin" on the actual replacement windows, lol...we did double hung pop-out pellas |
Here is a link that might be useful: http://www.coastalcontractor.net/pdf/2007/0705/0705repl.pdf
- Posted by jamesmrosas (My Page) on Mon, May 31, 10 at 7:20
| Hi pshomestead, How's your window replacement project? Have you installed it already? How did it go? |
