Removing a Stubborn Ceramic Tile from Bathroom Wall
Posted by chipster_2007 (My Page) on
Fri, May 6, 11 at 11:15
I am trying to remove 1 tile that is badly discolored from the bathroom wall. I have tried cutting around grout with a blade but that has not been successful. I have drilled holes in it hoping to be able to chip it off with a chisel. NO success. I am a little fearful about proceeding. Do I have any other options, ie could I fill in the drilled holes with something and then paint over it with a special paint if one exists or is there a better way to remove the tile? Any assist is greatly appreciated.
RE: Removing a Stubborn Ceramic Tile from Bathroom Wall
Drill holes and then break the tile up and remove the smaller pieces.
A plugging chisel for brick work has a narrow tip for clearing out mortar joints.
Use it in the hole you have driven into the joint between the tile and the backer it is on.
Brickeyee,
Where would i find a plugging chisel? In the big box stores? Thanks.
More likely a real hardware store.
They are usually about 1/4 inch wide to clean out mortar joints in brick.
A big box might have them around the masonry/brick supplies.
If you cannot find on a 1/4 inch cold chisel can be made to work, they are just harder to hit firmly.
