| Dear Friends:
Hopefully this forum will help me with this issue... I have a 139.53648SRT2 Model Craftsman Door Opener which I used several years for a 8' wide sliding door, actually I used two for two doors the same size at the same gate. Now, I remodeled my house and put a new single gate, 16' wide!, with double wheels and top and bottom.
- Posted by don_1_2006 (My Page) on Tue, May 25, 10 at 9:35
| These openers are limited by the design of the open and close limit assembly. Even adding an additional extension would not help you. Genie uses a simpler limit control which may be the answer to your problem. Unfortunately it involves replacing the opener. |
| Thanks Don... I was afraid that was my only solution. Blessings |
